Subtitles
Twowit2woo
Subtitles
#1 Post by Twowit2woo » Wed Aug 13, 2014 7:12 pm
I have just rebuilt my PC and installed MKV.
Previously, only the English subtitles were selected. Now all of them are.
Is this just a setting I've missed somewhere? I've had a look through all the options but cannot find anything obvious.
TIA
Re: Subtitles
#2 Post by Woodstock » Wed Aug 13, 2014 8:35 pm
What do you have for your preferred language? Tools -> Language -> Preferred language
Default setting is "none", which grabs everything.
If you enable "Expert mode", you can also set up a default selection rule in the Advanced tab that will appear.
Zlaxhe
Re: Subtitles
#3 Post by Zlaxhe » Thu Aug 14, 2014 7:49 am
You may right click on the movie title and choose unselect all and then just select the ones you want.
Sometimes it dosent know the language of the subs, then just choose all and play the mkv afterwards. Find out what subtitle is your preferred and unselect the other - choose open file and go for the .mkv file.
Twowit2woo
Re: Subtitles
#4 Post by Twowit2woo » Fri Aug 15, 2014 6:45 pm
Woodstock wrote:What do you have for your preferred language? Tools -> Language -> Preferred language
