Full Metal Jacket
Oreski5933
Full Metal Jacket
#1 Post by Oreski5933 » Sun Aug 10, 2014 4:59 pm
I tried to rip the movie and this is what the log says:
aving 1 titles into directory C:/Video/FULL_METAL_JACKET
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '16937250816'
DEBUG: Code 0 at !,+mNdHPXD/q|[j%Otd+:121263038
DEBUG: Code 0 at NKffz|Yk#yfOdimp%6`l:121261888
DEBUG: Code 0 at !,+mNdHPXD/q|[j%Otd+:213130559
DEBUG: Code 8270142 at !,+mNdHPXD/q|[j%Otd+:29393286
DEBUG: Code 0 at ){&>x>,?^(N$Rt<WLL~o@:213135090
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 0 to file C:/Video/FULL_METAL_JACKET/title00.mkv
0 titles saved, 1 failed
Re: Full Metal Jacket
#2 Post by Woodstock » Sun Aug 10, 2014 8:05 pm
Part of the disk isn't readable. Unfortunately, it was in a spot that made it impossible for MakeMKV to work around the problem.
Cleaning is the first thing to try.
bdkennedy1
#3 Post by bdkennedy1 » Wed Jun 29, 2016 1:25 am
Same movie, 2 different discs.
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 23129683968, attempting to work around
AV sync issue in stream 1 at 1:56:06.016 with duration of 32ms : broken timecode, apparent audio skew is -672ms
AV sync issue in stream 1 at 1:56:06.048 with duration of 160ms : audio gap - 5 missing frame(s)
AV sync issue in stream 1 at 1:56:06.336 with duration of 256ms : audio gap - 8 missing frame(s)
AV sync issue in stream 1 at 1:56:06.720 with duration of 32ms : broken timecode, apparent audio skew is -768ms
AV sync issue in stream 1 at 1:56:12.576 with duration of 32ms : broken timecode, apparent audio skew is -192ms
AV sync issue in stream 1 at 1:56:12.640 with duration of 32ms : broken timecode, apparent audio skew is -256ms
AV sync issue in stream 1 at 1:56:13.600 with duration of 32ms : broken timecode, apparent audio skew is -3104ms
AV sync issue in stream 1 at 1:56:17.120 with duration of 32ms : broken timecode, apparent audio skew is -96ms
AV sync issue in stream 1 at 1:56:06.784 with duration of 1024ms : audio gap - 32 missing frame(s)
AV sync issue in stream 1 at 1:56:07.872 with duration of 256ms : audio gap - 8 missing frame(s)
AV sync issue in stream 1 at 1:56:08.192 with duration of 2336ms : audio gap - 73 missing frame(s)
Failed to save title 0 to file /Volumes/Backup/title00.mkv
