Problem with Steven Wilson - Drive Home
cyborg
Post by cyborg » Sun Aug 10, 2014 2:36 pm
I have some problems with Steven Wilson's Blu-ray "Drive Home". The Blu-ray consists of several m2ts-files, which each contain a song. If I rip the Blu-Ray, the songs are combined in the mkv file. But there are some important frames dropped, which leads to one track missing the first milliseconds of its audio.
The log file:
MakeMKV v1.8.11 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\user/MakeMKV_log.txt
Title #00000.mpls has length of 14 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
File 00007.mpls was added as title #0
Title #00002.m2ts has length of 4 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00014.m2ts has length of 227 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00001.m2ts has length of 10 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00008.m2ts has length of 489 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00007.m2ts has length of 711 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00010.m2ts has length of 120 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00005.m2ts has length of 622 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00011.m2ts has length of 1 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00003.m2ts has length of 503 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00012.m2ts has length of 450 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00009.m2ts has length of 130 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00006.m2ts has length of 267 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00004.m2ts has length of 468 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Saving 1 titles into directory D:/Video
AV synchronization issues were found in file 'D:/Video/title00.mkv' (title #1)
AV sync issue in stream 1 at 0:07:37.255 with duration of 45.872s : audio gap was filled with silence
AV sync issue in stream 2 at 0:07:37.258 with duration of 2123.921ms : audio gap - 199.117 missing frame(s)
AV sync issue in stream 2 at 0:16:11.720 with duration of 4.208ms : encountered overlapping frame, audio skew is +4.208ms
AV sync issue in stream 2 at 0:26:34.634 with duration of 8.708ms : encountered overlapping frame, audio skew is +12.916ms
AV sync issue in stream 2 at 0:26:34.647 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +2.25ms
AV sync issue in stream 1 at 0:31:02.354 with duration of 5.791ms : audio gap was filled with silence
AV sync issue in stream 2 at 0:31:02.360 with duration of 0.875ms : short audio gap was removed, audio skew is -0.875ms
AV sync issue in stream 1 at 0:42:53.760 with duration of 19.041ms : audio gap was filled with silence
AV sync issue in stream 2 at 0:42:53.763 with duration of 17.25ms : audio gap - 1.617 missing frame(s)
AV sync issue in stream 2 at 0:51:05.773 with duration of 2421.333ms : 227 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 2 at 0:51:05.773 with duration of 6.25ms : encountered overlapping frame, audio skew is +6.25ms
AV sync issue in stream 1 at 0:51:05.776 with duration of 2425ms : 485 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 2 at 0:54:51.186 with duration of 608ms : 57 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 2 at 0:54:51.186 with duration of 5ms : encountered overlapping frame, audio skew is +11.25ms
AV sync issue in stream 2 at 0:54:51.198 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.583ms
AV sync issue in stream 1 at 0:54:51.188 with duration of 610ms : 122 overlapping frame(s) dropped at segment boundary
1 titles saved
MakeMKV drops some overlapping frames. MakeMKV probably drops the frames at the beginning of the m2ts file, which leads to missing audio at the beginning of one song.
When I directly open the mpls-file with MPC-HC, the audio is not missing and everything is fine.
Is there anything I can do to change this?
Re: Problem with Steven Wilson - Drive Home
Post by Woodstock » Sun Aug 10, 2014 8:03 pm
MakeMKV is trying to make the timestamps on the various tracks match up. You might try doing a backup with decryption, then turning Handbrake loose on the file to see whether it can synchronize the audio and video better.
