Suggested Setup?
vultureman
Suggested Setup?
Post by vultureman » Mon Apr 07, 2014 4:18 am
Is there a suggested device that seems to play MKVs from MakeMKV all of the time? There are tons of streaming devices out there nowadays.
I only have experience setting up an OPPO BDP-93 using TVersity as the streaming server, and that worked all of the time, but I'd like to find a small wired ethernet device that can handle MKVs properly AND play back content from Amazon.
Chetwood
Re: Suggested Setup?
Post by Chetwood » Mon Apr 07, 2014 4:17 pm
WDTV, but you need to turn on forced subs manually.
vultureman
Post by vultureman » Tue Apr 08, 2014 3:38 am
I forgot to mention one important thing (I'll edit it into the initial post): I'd also hope that the device can stream content from Amazon.
tstorzuk
Post by tstorzuk » Fri Aug 08, 2014 8:34 pm
I run all my files to my TV through a HTPC. You get everything you want using one. I also run XBMC on my HTPC so that I have a nice interface for my media files. But it's not necessary.
If you are interested in building a HTPC for yourself, check out the XBMC hardware forum. It's a great place to start.
I personally have 2 HTPC's built to this spec. It's the fastest one spec'd out on their site. I've also added the max RAM and an INTEL SSD into my builds though, which makes them even more expensive.
Hope that helps out.
