Cowboy Bebop -- Not finding all titles
crazy4nookie
#1 Post by crazy4nookie » Wed Nov 16, 2011 7:20 am
This DVD should have nine episodes but MakeMKV is finding one.
Debug log started at Wed Nov 16 07:13:27 2011 , written by MakeMKV v1.6.16 darwin(x86-release)
001005:0000 MakeMKV v1.6.16 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Volumes/Home/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL PIONEER DVD-RW  DVR-112D BC14" opened in OS access mode.
002015:0000 It's highly recommended to install DASPI kernel extension to improve performance.
003025:0000 Title #0 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003019:0000 Cells 7-end were skipped due to cell commands (structure protection?)
003028:0000 Title #1 was added (6 cell(s), 0:24:34)
003028:0000 Title #2 was added (1 cell(s), 0:03:34)
003025:0000 Title #3 has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003019:0000 Cells 2-end were skipped due to cell commands (structure protection?)
003025:0000 Title #4 has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=5 pgcn=1 hash=BCF27A5016D5CD3F
003025:0000 Title #5 has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #6 has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #7 was added (1 cell(s), 0:02:10)
003025:0000 Title #8 has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=9 pgcn=1 hash=C9152147C950195B
001003:0020 DEBUG: Code 233 at g05k9rFC8a1K8n4nmPXUNDIM:0
Application exited at Wed Nov 16 07:15:32 2011
crowfax
Re: Cowboy Bebop -- Not finding all titles
#2 Post by crowfax » Wed Nov 16, 2011 3:36 pm
crazy4nookie
#3 Post by crazy4nookie » Wed Nov 16, 2011 10:35 pm
Oops, here are the IFO files
bebop VIDEO_TS.zip
(96.24 KiB) Downloaded 990 times
crazy4nookie
#4 Post by crazy4nookie » Fri Nov 18, 2011 11:30 pm
Looks like this DVD is not the same issue as I had in the Speed Grapher post. That one ended up having all the episodes within one large title. This one should have nine episodes each having several chapters in it, but instead its showing up as follows.
#5 Post by mike admin » Sun Dec 04, 2011 6:26 am
The next version of MakeMKV will properly handle this disc, and all discs that are mastered like this one. Thank you for sending the log file.
nalybuites
#6 Post by nalybuites » Fri Aug 08, 2014 3:51 am
Has this issue actually been fixed? I'm seeing the same thing with the Cowboy Bebop discs as well and running MakeMKV v1.8.11 win(x64-release). The current version appears to only be unable to extract all titles from discs 2 and 3. I can profide IFOs and logs if that is helpful.
ndjamena
#7 Post by ndjamena » Fri Aug 08, 2014 5:03 am
nalybuites
#8 Post by nalybuites » Fri Aug 08, 2014 11:55 am
Unfortunately, that didn't help. I'm unable to upload the IFOs due to the error message "Sorry, the board attachment quota has been reached.". I've put them on private hosting here:
[downloaded]
nalybuites
#9 Post by nalybuites » Fri Oct 24, 2014 5:05 pm
Any updates here?
#10 Post by Woodstock » Fri Oct 24, 2014 11:10 pm
I haven't been following this, but... Which release of Bebop? When I ripped the original release 2 years ago, MakeMKV found all the titles on all disks. I'd have to get them out of storage to check them against the current release of MakeMKV.
nalybuites
#11 Post by nalybuites » Mon Oct 27, 2014 6:22 pm
It's the regular DVD release of Cowboy Bebop Remix: http://www.amazon.com/gp/product/B00102 ... UTF8&psc=1
It's possible that I purchased a bootleg copy, since it's sold by some marketplace seller, rather than Amazon directly. Though I would expect a bootleg to be easier to extract from.
#12 Post by Woodstock » Mon Oct 27, 2014 11:11 pm
Checking that this IS the 2008 Bandai 6-disk Anime Legends release... Found mine, so I can check it... It's an excuse to convert what's on the media server to MKV. :)
I'll post the results of my scans vs. what the box says is on one disks later.
#13 Post by Woodstock » Tue Oct 28, 2014 12:51 am
MakeMKV 1.8.14 can handle the Bandai release.
If the original poster had 9 episodes on a disk, they did NOT have one of the official Bandai releases. I have bought some series out of China and Indonesia that packed that many episodes on a DVD, but Bandai did not normally do so.
What my case says per disk, and what MakeMKV could do with it (I did not re-rip extras this time, watched them already):
Disk 1: Episodes 01-05 -> MakeMKV found 5 plus extras, ripped 5
Disk 2: Episodes 06-10 -> MakeMKV found 5 plus extras, ripped 5
Disk 3: Episodes 11-14 -> MakeMKV found 4 plus extras, ripped 4
Disk 4: Episodes 15-18 -> MakeMKV found 4 plus extras, ripped 4
Disk 5: Episodes 19-22 -> MakeMKV found 4 plus extras, ripped 4
Disk 6: Episodes 23-26 -> MakeMKV found 4 plus extras, ripped 4
Now, there was an issue with the episodes NOT being in order on the first two disks - I had to watch each long enough after the rip to make sure they had the correct file names, before I turn them over to Handbrake....
Not to mention that all 6 disks were mastered at different times, so audio track type and order changes between them.
nalybuites
#14 Post by nalybuites » Tue Oct 28, 2014 2:42 pm
That's the layout of the discs that I have, however, MakeMKV is not picking up any titles on discs 2 and 3. I'll see if it's been updated since and then try again.
#15 Post by Woodstock » Tue Oct 28, 2014 2:57 pm
If Mike needs to see logs and IFO files from successful rips, I can supply those.
