Streaming + Hamachi2 = Wrong IP
war59312
#1 Post by war59312 » Mon Mar 01, 2010 5:30 am
If you are using https://secure.logmein.com/products/hamachi2/ and enable the stream feature in MakeMKV, it want's to use the assigned hamachi IP address (5. range ip address).
This is wrong, it should use your private IP address assigned to your nic.
Note: It still works fine but you have to manually change IP to your private.
Take Care,
Will
