Another disk with a boatload of files. About a third have the proper runtime. Still way too many. Was wondering if anyone had it figured out, yet.
Doc
"Divergent" "rental" disc correct file number: 810
DrDon
zordaz
Re: "Divergent" correct file?
I check to total play time of the DVD using either a dvd player or VLC media player. Then I look for the closest matching file with that time. That is the one I use and it is usually the right one..
DrDon
Another thread says there are two that fit that criteria. 565 and 810. I'm ripping both of those just to be sure. Thanks.
lemonstrike8
not sure if you just read the title and posted or didn't understand what the OP said... but the OP stated he has done that..... and a third of them DO match the run time. Just looking at run time will not pin-point the correct title.zordaz wrote:I check to total play time of the DVD using either a dvd player or VLC media player. Then I look for the closest matching file with that time. That is the one I use and it is usually the right one..
DrDon
In Zordaz's defense, I was using the runtime as reported by a Google search, which was not to the nearest second. In another thread, someone posted the runtime to the second along with the two playlists that matched. I've ripped both.
Meanwhile FWIW, SlySoft is having to issue a patch since their software can't copy this movie, either.
Gronnie
Please post once you verify which (if any) of the two you ripped is correct.
lemonstrike8
pt: 2:19:40 = 565 and 810DrDon wrote:Another thread says there are two that fit that criteria. 565 and 810. I'm ripping both of those just to be sure. Thanks.
565 skips a head at 25:39 so 810 is correct
WAYFLIX
Thanks!lemonstrike8 wrote:565 skips a head at 25:39 so 810 is correctDrDon wrote:Another thread says there are two that fit that criteria. 565 and 810. I'm ripping both of those just to be sure. Thanks.
nickbuol
That is for the Redbox version correct? Just trying to clarify for others. The retail versions may be different. The Target Exclusive 3-disc set doesn't even have a 565 or an 810. I grabbed the 760.mpls and am going to verify it tomorrow. It has the correct runtime (so does 019.mpls). Just need to confirm the segment order.
Someone else reported that 760.mpls from the Amazon version was the only correct version for that disc, and the segment map matched the 760.mpls from the Target one.
My guess is that the retail versions (which also have HD audio) are going to be less hassle too since they don't have nearly as many bogus titles either. Just a thought for all of the "rent and rip" folks if they haven't rented yet.
EDIT: Title of this thread has been modified by the original poster to now reflect the rental version with 810.mpls. Retail versions will be different.
blacktop
Is there a way to uncheck all of those titles and then check just the one you want? Thanks. Never mind just found old post - right click.
DrDon
Re: "Divergent" "rental" disc correct file number: 810
I was working with the Netflix disc which says "rental" on it. Probably same version.
Title edited to reflect the solution so nobody has to sift through the thread.
thevofl
OK. I may be rather ignorant with this, but what does a person using MakeMKV do with the "810"?
I have the non-Blu-Ray version.
thevofl
Nevermind, I watched the movie. I won't watch it again.thevofl wrote:OK. I may be rather ignorant with this, but what does a person using MakeMKV do with the "810"?
byrdmanlk
Sorry i am a little new but how do you tell you are on file 810?
goingbust
File 00810.mpls was added as title #249byrdmanlk wrote:Sorry i am a little new but how do you tell you are on file 810?
Right click on the area with checkboxes and do a Unselect all. Scroll down until you find this line, check just that one, then rip.
Edit: Jesus fuck, this movie sucks. Don't bother. Burn disc, stat!
