Robocop 2014 return errors.... finishing in...
Highest AACS version is v47 , MKB saved as C:\Users\......../.MakeMKV/MKB_v47_I_FRANKENSTEIN.tgz
I emailed the TGZ to support@makemkv.com, hope it helps!
Robocop 2014
Robocop 2014
Registered user
Linux / Windows 10
Asus BW-16D1HT 3.10MK x2
Asus BC-12D2HT 3.11MK
LG BH16NS40 flashed to WH16NS60 1.03
LG GGC-H20L 1.03
Pioneer BDR-205 GENE
Linux / Windows 10
LG GGC-H20L 1.03
Re: Robocop 2014
Hi, i also have problems with this disc.
Is there any log or something else i can provide to improve makemkv?
Title #1 has length of 22 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #2 has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #3 has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #4 has length of 4 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Cells 2-end were skipped due to cell commands (structure protection?)
Title #5 was added (1 cell(s), 0:02:16)
Title #6 was added (1 cell(s), 0:02:19)
Title #7 was added (1 cell(s), 0:01:18)
Cells 11-end were skipped due to cell commands (structure protection?)
Title #8 was added (10 cell(s), 0:03:32)
Title #9 has length of 26 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #10 has length of 25 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #11 has length of 22 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #12 has length of 24 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #13 has length of 15 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #14 has length of 18 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #15 has length of 21 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #16 has length of 21 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #17 has length of 16 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #18 has length of 27 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Cells 6-end were skipped due to cell commands (structure protection?)
Title #19 was added (5 cell(s), 0:03:53)
Title #20 was added (1 cell(s), 0:00:32)
Title #21 was added (1 cell(s), 0:00:46)
Title #22 was added (1 cell(s), 0:01:24)
Title #23 was added (1 cell(s), 0:00:40)
Title #24 was added (1 cell(s), 0:00:31)
Title #25 was added (1 cell(s), 0:05:50)
Title #26 was added (1 cell(s), 0:14:18)
Title #27 was added (1 cell(s), 0:02:09)
Title #28 was added (1 cell(s), 0:00:31)
Cells 35-37 were skipped due to cell commands (structure protection?)
Cells 40-end were skipped due to cell commands (structure protection?)
Title #29 was added (33 cell(s), 1:52:41)
Title #30 was added (1 cell(s), 0:02:09)
Title #31 was added (1 cell(s), 0:07:27)
Title #32 was added (1 cell(s), 0:01:30)
Cells 1-1 were removed from title start
Cells 3-3 were removed from title end
Title #33 was added (1 cell(s), 0:02:18)
Title #34 was added (1 cell(s), 0:02:17)
Title #35 has length of 4 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #36 was added (1 cell(s), 0:09:02)
Title #37 was added (1 cell(s), 0:24:24)
Title #39/9 has length of 18 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #39/11 has length of 19 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #39/27 has length of 15 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #40 has length of 4 seconds which is less than minimum title length of 30 seconds and was therefore skipped
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-3 were removed from title start
Cells 49-49 were removed from title end
Title #41 (1:58:06) was skipped due to navigation error
Title #42/0/1 was added (37 cell(s), 1:51:49)
Title #43/0/1 was added (40 cell(s), 1:50:26)
