Subtitels
sjoef
Subtitels
Post by sjoef »
Hello, i am new with makemkv. I have a iso with dutch subtitels. When i make a mkv file i do not have the dutch subtitels. I select the iso file, after reading i select under title Audio and subtitels, (i olso tryed to selected dutch forced, but after converting the programm give a message that the forced was empty and removed). Than i press make MKV. But still no subtitels on my appletv. I can choose Off, Automatic an CC. All the options have no result. What do i wrong?
JoZ
ndjamena
Re: Subtitles
Post by ndjamena »
For one thing AppleTV doesn't support MKV natively, but I guess you know that and have found a way around. The other is that AppleTV doesn't support PGS subtitles so unless you've run them through OCR and converted them to SRT you won't be able to see them, I'm pretty sure there's no easy way around that.
