Errors Producing Failure
dizzie
Post by dizzie »
Tried it on 1.8.1 and now on 1.8.11. Thanks for any assistance. Details:
MakeMKV v1.8.11 darwin(x86-release) started
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-875 DB09" opened in DASPI v1.3 mode.
Optical drive "BD-RE PIONEER BD-RW BDR-TD03 1.20" opened in DASPI v1.3 mode.
Loaded 141 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
BD+ code processed, got 1 FUT(s) for 1 clip(s)
Title #00888.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #0
Title #00720.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.mpls has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00850.mpls is equal to title 00800.mpls and was skipped
File 00458.mpls was added as title #1
File 00459.mpls was added as title #2
Title #00460.mpls has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00461.mpls has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00462.mpls has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00463.mpls has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00464.mpls has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00465.mpls has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00466.mpls has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00457.mpls was added as title #3
File 00455.mpls was added as title #4
File 00456.mpls was added as title #5
Title 00851.mpls is equal to title 00800.mpls and was skipped
Title 00801.mpls is equal to title 00800.mpls and was skipped
Title #00062.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00888.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00502.m2ts was added as title #6
File 00501.m2ts was added as title #7
Title #00503.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00507.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00504.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00509.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00508.m2ts has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00506.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00505.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00510.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00511.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00469.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00451.m2ts has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00452.m2ts has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00470.m2ts was added as title #8
File 00471.m2ts was added as title #9
Title #00454.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00453.m2ts was added as title #10
Title #00472.m2ts has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00499.m2ts was added as title #11
Saving 1 titles into directory /Volumes/Storage
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00500.m2ts' at offset '368320512'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00500.m2ts' at offset '368326656'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00500.m2ts' at offset '368381952'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00500.m2ts' at offset '368394240'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00500.m2ts' at offset '368812032'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00500.m2ts' at offset '1738930176'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00500.m2ts' at offset '1738942464'
Failed to save title 0 to file /Volumes/Storage/Diary_of_a_Wimpy_Kid_t00.mkv
0 titles saved, 1 failed
Re: Errors Producing Failure
There are at least two spots on the disk that your drive cannot read. If it can't read it, MakeMKV will not be able to save the file.
First step is to clean the disk. I prefer cleaning with Pledge furniture polish, because the wax fills in tiny scratches you can't see, and can make some disks readable that otherwise wouldn't.
dizzie
Post by dizzie »
Nice, will do!
