Error Moving File, Sequence contains no elements
thousandbuckle
Post by thousandbuckle »
Hello all, I have a folder that contains workout videos I ripped from my DVD to play through Plex on the TV. The root folder path is E:\Media\Insanity. When I load the root folder MakeMKV see's all of the IFO files in the root folder. Weird thing is some will convert and some will fail. All the rips are main title with no menus in them and all play fine using VLC. They are all in the same folder ripped with the same setting and application so why do some convert and some fail?
The ones that fail provide the error message "Error Moving File, Sequence contains no elements". If I convert the rips that fail in the MakeMKV it works fine but when I use the MakeMKV batch converter it fails. Can any one help me with this?
Re: Error Moving File, Sequence contains no elements
You won't get menus with MKV files - there is no place to put them in the file.
Turn on debug logging (link in my signature) to get us some information on what is failing.
