Harry Potter Blurays
Oreski5933
I have had issues ripping the Harry Potter blurays. The program will rip everything except the film itself, them it says titles failed to be saved. Anyone have a fix for this?
Re: Harry Potter Blurays
All of the Harry Potter BDs ripped fine for me, so... Start by enabling debug logging (link in my signature), and posting the log from a rip here in a reply.
kimja215
Ripped all of them a few weeks ago. worked fine
yaltru
I am also having trouble with the Harry Potter blurays. I tried the first three in the series, and all failed.
Below is the output from HP1 attempt.
TIA
Debug log started at Fri Aug 29 21:57:15 2014 , written by MakeMKV v1.8.12 linux(x64-release)
001005:0000 MakeMKV v1.8.12 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/user/MakeMKV_log.txt
DAFD=PAAAADAAAAEABDQkEHgACAQ==
DCE=mHpYOU3DT9zC0Qbmb0xXzO/xQ0SDtaF2F7QMqMj+LC66zhVKr7BO/krQtItONixIYIMgk4d5LhiB2xY15Kh/G+N5iVMGK7+I28Caf8o1Cz5GHuRaSAMCZbzQExULHsjB2iKzGqfYjAzs/SyhTRFcg+tUvLkIgk25yA==
DCE=Z0QiADqYN1UdTfckvo+VVKCBYGFfxtTJ9f2PwS77/j72QWhEJzYvx0OA9InY5yBnFIXN01qPqkhyhwdM6f7iSZRko7lDmcSZvn2rU1KAVtQWagMtv3QDrtf77Ril4J2WcJqPtYIO9FF/APBIYsGPiFnOLreQa7sxtg==
DISCID=834927B2F368FADBCDF773E5FD724BC27B9D4F1E
003307:0000 File 00000.mpls was added as title #0
003025:0000 Title #00033.mpls has length of 59 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00017.mpls has length of 539 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003307:0000 File 00002.m2ts was added as title #1
003025:0000 Title #00003.m2ts has length of 38 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 31 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 64 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 64 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 64 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 64 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 64 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 64 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 64 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 64 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 110 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 143 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 54 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 37 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 38 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 20 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 60 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 117 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00023.m2ts has length of 208 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00024.m2ts has length of 11 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00025.m2ts has length of 11 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00026.m2ts has length of 0 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00027.m2ts has length of 23 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00032.m2ts has length of 44 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00036.m2ts has length of 59 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00098.m2ts has length of 34 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00099.m2ts has length of 34 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00100.m2ts has length of 34 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00107.m2ts has length of 63 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00109.m2ts has length of 34 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00110.m2ts has length of 63 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00112.m2ts has length of 34 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00113.m2ts has length of 62 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00115.m2ts has length of 34 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00116.m2ts has length of 62 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00118.m2ts has length of 31 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00119.m2ts has length of 29 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00120.m2ts has length of 29 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00121.m2ts has length of 43 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00122.m2ts has length of 34 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00123.m2ts has length of 21 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00124.m2ts has length of 27 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00125.m2ts has length of 34 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00126.m2ts has length of 30 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00127.m2ts has length of 20 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00128.m2ts has length of 27 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00129.m2ts has length of 27 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00130.m2ts has length of 29 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00131.m2ts has length of 54 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00132.m2ts has length of 37 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00133.m2ts has length of 32 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #00134.m2ts has length of 37 seconds which is less than minimum title length of 600 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /home/user/Videos/tmp
001003:0020 DEBUG: Code 0 at 8'[{tp{.p&:CE''0Eky':121268535
001003:0020 DEBUG: Code 0 at i#=|%ltxhzS)`m~:121264717
001003:0020 DEBUG: Code 196608 at t46nq,(Vf/47<47GI`:121264280
001003:0020 DEBUG: Code 0 at t46nq,(Vf/47<47GI`:213134469
001003:0020 DEBUG: Code 0 at t46nq,(Vf/47<47GI`:121267914
001003:0020 DEBUG: Code 0 at t46nq,(Vf/47<47GI`:213136792
005003:0000 Failed to save title 0 to file /home/user/Videos/tmp/title00.mkv
005004:0080 0 titles saved, 1 failed
TIA
ndjamena
My #1 has a TrueHD main track... they must have re-encoded it when they changed the name from 'Sorcerer's Stone' to 'Philosopher's Stone'. I'm assuming you're American, which means all the early HP movies would have 5.1 PCM audio which v1.8.12 can't rip. You'll have to downgrade to v1.8.11.
yaltru
Yes, American. I downgraded to 1.8.11 and the import seems to be working now.
Thanks.
Thanks.
PulsarAV
I can confirm that V1.8.12 is having problems ripping some of the Harry Potter BD's
I had problems with the following:
Harry Potter and the Order of the Phoenix (2007)
Harry Potter and the Prisoner of Azkaban (2004)
Harry Potter and the Sorcerer's Stone (2001)
Downgrading to V1.8.11 corrected the issue.
The other Harry Potter BD's converted fine with V1.8.12
If anyone wants the debug log, let me know.
~PulsarAV~
~PulsarAV~
Warrzone
MakeMKV 1.8.12 has an LPCM bug http://www.makemkv.com/forum2/viewtopic.php?f=8&t=8202. You have to use 1.8.11 for any movies with LPCM http://www.makemkv.com/download/old/.
Romansh
Looks like the LPCM bug.
mancolh
I just ripped the LPCM with 1.8.13 yesterday (and also converted it to FLAC as well as kept the original) and it worked with no issues
