Brand new disc -- fails to open on two different systems.
Debug log started at Sat Jul 05 16:58:32 2014 , written by MakeMKV v1.8.11 win(x64-release)
001005:0000 MakeMKV v1.8.11 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Tom/MakeMKV_log.txt
001003:0020 DEBUG: Code 2 at J{bGLJEkzjZEw"^Y:213137827
001003:0020 DEBUG: Code 101019395 at f{gB<gwK*e1g'1,{(D:213132100
001003:0020 DEBUG: Code 101019395 at f{gB<gwK*e1g'1,{(D:29393930
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'BD-RE MATSHITA BD-MLT UJ260AF 1.00' at offset '1048576'
Title skip vts=1 pgcn=1 hash=10D00FBCF976D07D
Application exited at Sat Jul 05 16:59:22 2014
Walt Disney - George of the Jungle (film) DVD
OldTimerToo
Promod117
Re: Walt Disney - George of the Jungle (film) DVD
I'm having a problem with this movie also. Here is my debug log. For whatever reason, it saved it in one line originally.
Any help would be appreciated!
Debug log started at Fri Jul 25 03:10:02 2014 , written by MakeMKV v1.8.11 win(x64-release)
001004:0000 Debug logging enabled, log will be saved as C:\Users\Paul/MakeMKV_log.txt
005010:0000
005010:0000
Application exited at Fri Jul 25 03:12:07 2014
005010:0000
005010:0000
jshatch
I have the same problem with the same DVD:
Debug log started at Mon Jul 28 06:50:33 2014 , written by MakeMKV v1.8.11 win(x64-release)
001004:0000 Debug logging enabled, log will be saved as C:\Users\J/MakeMKV_log.txt
Title skip vts=1 pgcn=1 hash=13DA9706A19047BC
Application exited at Mon Jul 28 06:51:03 2014
Disc Information
Label: GEORGE
Timestamp: 1997-12-03 05:38:31
Data capacity: 4.25 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 1 (PTP)
Disc Information
Label: GEORGE
Disc type: DVD-ROM
Disc size: 120mm
Promod117
I tried this on an XP machine. Here is the log from there.
MakeMKV v1.8.11 win(x86-release) started
DEBUG: Code 101019395 at %ZQj^^*JFH)ippY\Og:213132100
DEBUG: Code 101019395 at %ZQj^^*JFH)ippY\Og:29393930
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'DVD+R-DL HL-DT-ST DVD+-RW GH30N A102' at offset '1048576'
