richard@jufer.net
Post
by richard@jufer.net » Sat Jul 26, 2014 6:06 pm
HELP .......
MakeMKV always puts _t00 at the end of the file name and it also puts the "_" character between words in the title of the movie file. So ....
"An American Carol"
becomes "An_American_Carol_t00"
Is there anyway to stop this? My version does not seem to have a way to do this .... I
DO NOT WANT THE NAME CHANGED !!!!
I have version 1.8.11
Sincerely,
Richard T. Jufer
ndjamena
Post
by ndjamena » Sun Jul 27, 2014 3:38 am
This has been one of the most requested features. So far manually editing the file names is the only option.
Or if you use windows you could try this .bat file:
@if "%EMode%"=="" Set EMode=OFF
@ECHO %EMode%
SetLocal DisableDelayedExpansion
Set "EXTLIST=*.mkv"
Set "DoPop="
if [%1]==[] (
Set "Pattern=%EXTLIST%"
CALL :START %1
:ARGS
if [%1]==[] (
EndLocal
pause
goto :eof
if NOT EXIST %1 (
SHIFT
goto :ARGS
if "%~f1"=="%CD%" (
CALL :START %1
SHIFT
goto :ARGS
Type NUL
pushd "%~f1" 2> nul
if NOT "%errorlevel%"=="0" (
if NOT "%CD%\"=="%~dp1" (
pushd "%~dp1"
Set "DoPop=1"
Set Pattern="%~nx1"
) else (
Set "DoPop=1"
CALL :START %1
if "%DoPop%"=="1" (
popd
Set "DoPop="
SHIFT
goto :ARGS
:START
for %%y in (%Pattern%) do (
CALL :Process_File "%%~fy"
goto :eof
:Process_File
echo Processing; "%~nx1"
Set "Work=%~n1"
if "%Work:~-4,1%"=="_" if "%Work:~-3,1%"=="t" (
Set "Work=%Work:~0,-4%"
Set "Work=%Work:_= %"
if NOT "%~n1"=="%Work%" (
echo Renaming "%~nx1" to "%Work%%~x1"
ren "%~f1" "%Work%%~x1"
EndLocal
goto :eof
Post
by Woodstock » Sun Jul 27, 2014 4:41 am
If you haven't already, go to the Tools->General menu, and enable Expert Mode.
That will add some functionality to the selection screen, after you open the disk. Not only will you be able to edit the name embedded in the file, but you can also change the file name written.
And yes, getting rid of the _ replacing spaces would be wonderful. If I were really ambitious, I'd dig through the executable and find where the substitution is done, and change it there, so it would automatically replace spaces with ... spaces!
Alas, I'm not that ambitious yet...
Chetwood
Post
by Chetwood » Sun Jul 27, 2014 4:54 am
Me neither, that's why I'm using Total Commanders MUT with a saved profile.
