Makemkv fails to convert the blu-ray "La vie d'ad?le" (SKU: 2XVDVDWPIQAKX) with bad sector error. The blu-ray (brand new, no scratchs or anything else) plays fine in my BL player. Interesting info : anydvd fails also.
S.
Impossible to convert the Blu-Ray "La Vie D'ad?le"
mottelet
mottelet
Re: Impossible to convert the Blu-Ray "La Vie D'ad?le"
More precisely, I have the following errors :mottelet wrote:Hello,
S.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '5446889472'
I use MakeMKV 1.8.11 and the Disc is reported to use AACS V46
S.
And MakeMKV and Anydvd are reporting the problem to you - the disk has a bad spot on it.
Remember, DVD and Bluray players are PROGRAMMED TO IGNORE MINOR ERRORS. You may not notice a glitch in the video or audio, or you might, but they'll plow through it. There is enough redundancy in the video stream to make up for a missing frame or three.
But tools meant to rip an ACCURATE copy of the disk will complain when confronted with unreadable sectors.
trumpet205
Get a replacement disc, it is faulty.
Blu-ray players are programmed to skip unreadable sector, hence it will play fine even though the disc is faulty.
