Errors with Grand Budapest Hotel Blu-ray
pd1215
Post by pd1215 » Tue Jul 22, 2014 10:59 pm
Hi there,
I keep getting an error pop-up during the initial scan of The Grand Budapest Hotel. The error message is, "BD+ code processed but no FUTs were obtained, errors may follow". I proceeded anyways and encoded the disc with Handbrake. The movie was very pixelated and rendered in 4x3 aspect ratio instead of the normal 16x9. Pretty much unwatchable. I've tried twice so far with different discs - same result. Any help would be greatly appreciated!
Thanks! :o
scottstone
Re: Errors with Grand Budapest Hotel Blu-ray
Post by scottstone » Wed Jul 23, 2014 2:55 am
I got the same errors, same pixelation and same 4x3 aspect ratio as pd1215. any thoughts?
Post by mike admin » Wed Jul 23, 2014 8:58 am
Use the latest version, 1.8.11 .
scottstone
Post by scottstone » Wed Jul 23, 2014 3:15 pm
After updating to 1.8.11 MKV worked perfectly for this movie.
pd1215
Post by pd1215 » Wed Jul 23, 2014 3:17 pm
Confirmed. Did the trick for me too! Thanks for the help!! :D
YouWho
Post by YouWho » Fri Jan 16, 2015 5:43 am
Hi All-
Just tried to put this movie into my Plex library tonight and I am getting a failure due to SCSI Errors. I have seen this before and makemkv managed to power through that disk, but this time it is just not cutting it. Here are the errors from the progress window and also the log file which I generated since this is the second machine I have tried it on and the errors are from the same sectors on the BD. I checked the BD and wiped it down with a microfiber cloth to get any smears off of it and it looks pretty clean and scratch free. I did up the error retry to 10.
My setup :
Mac Book Pro i7 2.3GHz/8Gb/1Tb SSD
Mac OSX 10.10.1
makeMKV 1.9.0
--snip--
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00106.m2ts' at offset '661192704'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00106.m2ts' at offset '661585920'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00106.m2ts' at offset '663355392'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00106.m2ts' at offset '664006656'
--snip--
Logfile: (tried to attach but got error about quota reached)
$ cat MakeMKV_log.txt
Debug log started at Fri Jan 16 04:24:20 2015 , written by MakeMKV v1.9.0 darwin(x86-release)
001005:0000 MakeMKV v1.9.0 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/pacyga/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL MATSHITA DVD-R   UJ-8A8 HA13d" opened in OS access mode.
002010:0000 Optical drive "BD-RE TSSTcorp BDDVDW SE-506BB TS00d" opened in OS access mode.
DAFD=PAAAADAAAAEABDQkEHwECAQ==
DCE=9xkWEMoP1sFNJSXMHda4XgWQJz8UUI1cjT70GwUfqVmLz+2YHHYgulWTPai5NGN7jmnkrh9m0r6QrqWI8wMh5HlDxXiS2i7OFtalUi35pmyr9pwu2zf02HA+tanoHNMKEMivFXsVJQhfD6/HTkoeym3WQ4YmOU7iKA==
DCE=QqxbRDRBEe8TPFhf+pgupes28mhljO9n75kruxMVfLQMRjbZSuMPqg1YkcVHDy8UFBjt2CedFH8hgOXG9Yr/oX4HICg0L4tnRhzTQ0BeQm1t4qIPifjPaBm8OmjZilaiVkmePoGX17dUhxpCtMGIwq/Ir82QQzk1uQ==
003317:0000 Loaded 51 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00000.svq
SVQ: generic005 builtin/00000.svq
003332:0000 Saved BD+ dump file as /Users/pacyga/Library/MakeMKV/dump_The_Grand_Budapest_Hotel_68139AB131072D50.tgz
003328:0000 BD+ code processed, got 1 FUT(s) for 19 clip(s)
DISCID=68139AB131072D5084FF31D5FB52882459D4BAE6
003308:0000 File 00800.mpls (angle 1) was added as title #0
003308:0000 File 00800.mpls (angle 2) was added as title #1
003308:0000 File 00800.mpls (angle 3) was added as title #2
003308:0000 File 00800.mpls (angle 4) was added as title #3
003309:0000 Title 00850.mpls is equal to title 00800.mpls and was skipped
003041:0000 Failed to add angle #2 for title #850
003041:0000 Failed to add angle #3 for title #850
003041:0000 Failed to add angle #4 for title #850
003307:0000 File 00480.mpls was added as title #4
003307:0000 File 00437.mpls(1) was added as title #5
003025:0000 Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00061.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00081.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00082.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00086.m2ts was added as title #6
003025:0000 Title #00087.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00091.m2ts was added as title #7
003025:0000 Title #00092.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00096.m2ts was added as title #8
003025:0000 Title #00097.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00101.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00102.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00106.m2ts was added as title #9
003025:0000 Title #00107.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00111.m2ts was added as title #10
003025:0000 Title #00112.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00116.m2ts has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00117.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00121.m2ts was added as title #11
003025:0000 Title #00122.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00126.m2ts was added as title #12
003025:0000 Title #00127.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00131.m2ts was added as title #13
003025:0000 Title #00132.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00136.m2ts was added as title #14
003025:0000 Title #00137.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00141.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00142.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00146.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00147.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00151.m2ts was added as title #15
003025:0000 Title #00152.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00156.m2ts was added as title #16
003025:0000 Title #00161.m2ts has length of 89 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00162.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00166.m2ts was added as title #17
003025:0000 Title #00167.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00171.m2ts was added as title #18
003025:0000 Title #00172.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00185.m2ts was added as title #19
003307:0000 File 00186.m2ts was added as title #20
003307:0000 File 00187.m2ts was added as title #21
003307:0000 File 00188.m2ts was added as title #22
003307:0000 File 00189.m2ts was added as title #23
003307:0000 File 00190.m2ts was added as title #24
003307:0000 File 00191.m2ts was added as title #25
003307:0000 File 00192.m2ts was added as title #26
003307:0000 File 00193.m2ts was added as title #27
003307:0000 File 00194.m2ts was added as title #28
003025:0000 Title #00196.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00197.m2ts was added as title #29
003025:0000 Title #00198.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00199.m2ts was added as title #30
003025:0000 Title #00200.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00201.m2ts was added as title #31
003025:0000 Title #00202.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00203.m2ts was added as title #32
003307:0000 File 00204.m2ts was added as title #33
005014:0000 Saving 1 titles into directory /Volumes/Library-BackUp/Blu-Ray
AV sync issues in /Volumes/Library-BackUp/Blu-Ray/The_Grand_Budapest_Hotel_t00.mkv
AV sync in 1 at 0:00:37.120 (10.25ms) : encountered overlapping frame, audio skew is +10.25ms
AV sync in 1 at 0:01:04.647 (3.166ms) : encountered overlapping frame, audio skew is +13.416ms
AV sync in 1 at 0:01:04.661 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +2.75ms
AV sync in 1 at 0:05:25.033 (9.541ms) : encountered overlapping frame, audio skew is +12.291ms
AV sync in 1 at 0:05:25.045 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +1.625ms
AV sync in 1 at 0:05:47.847 (1.541ms) : encountered overlapping frame, audio skew is +3.166ms
AV sync in 1 at 0:14:17.189 (1.833ms) : encountered overlapping frame, audio skew is +5ms
AV sync in 1 at 0:14:42.256 (10.625ms) : encountered overlapping frame, audio skew is +15.625ms
AV sync in 1 at 0:14:42.272 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +4.958ms
AV sync in 1 at 0:18:27.606 (4.541ms) : encountered overlapping frame, audio skew is +9.5ms
AV sync in 1 at 0:18:51.463 (4.166ms) : encountered overlapping frame, audio skew is +13.666ms
AV sync in 1 at 0:18:51.477 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +3ms
AV sync in 1 at 0:19:56.236 (5.625ms) : encountered overlapping frame, audio skew is +8.625ms
AV sync in 1 at 0:20:21.428 (2.833ms) : encountered overlapping frame, audio skew is +11.458ms
AV sync in 1 at 0:20:21.440 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +0.791ms
001003:0020 DEBUG: Code 1073741829 at #x-ibTGr3v0+qxa(:29393953
001003:0020 DEBUG: Code 2 at |<tnvl}zoIA??==#:213137827
001003:0020 DEBUG: Code 513 at j'D.A.xp&rb/WnDR:213138333
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00106.m2ts' at offset '661192704'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00106.m2ts' at offset '661585920'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00106.m2ts' at offset '663355392'
001003:0020 DEBUG: Code 4097 at j'D.A.xp&rb/WnDR:213138333
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00106.m2ts' at offset '664006656'
001003:0020 DEBUG: Code 2049 at j'D.A.xp&rb/WnDR:213138333
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00106.m2ts' at offset '664467456'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00106.m2ts' at offset '664479744'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00106.m2ts' at offset '664485888'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00106.m2ts' at offset '664504320'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00106.m2ts' at offset '664522752'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00106.m2ts' at offset '664528896'
001003:0020 DEBUG: Code 0 at j'D.A.xp&rb/WnDR:29396529
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00106.m2ts' at offset '664664064'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00106.m2ts' at offset '665321472'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00106.m2ts' at offset '665714688'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00106.m2ts' at offset '665972736'
001003:0020 DEBUG: Code 0 at #[fvxFw_#|}fE>q64"|w:121263038
001003:0020 DEBUG: Code 0 at |#BDWd;;gSWL#?SF^?$^:121261888
001003:0020 DEBUG: Code 0 at #[fvxFw_#|}fE>q64"|w:213130559
001003:0020 DEBUG: Code 325182 at #[fvxFw_#|}fE>q64"|w:29393286
001003:0020 DEBUG: Code 0 at A8n%qaCAO/eaM@T2R8y!%:213135090
005003:0000 Failed to save title 0 to file /Volumes/Library-BackUp/Blu-Ray/The_Grand_Budapest_Hotel_t00.mkv
005004:0080 0 titles saved, 1 failed
Any ideas?
Post by Woodstock » Fri Jan 16, 2015 2:35 pm
You've recognized the problem - your drive cannot read parts of the disk.
My next step would be to treat the disk using a compatible wax (Pledge furniture polish works) and a soft cotton or microfiber cloth, and trying the rip again.
Pledge cleans up finger print, and its wax fills in minor scratches that can cause read errors but not be easily seen. Pledge has worked so well for me for this sort of mischief that I don't bother with trying to wipe disks down without it. Spray it on, use a clean finger to rub it in, then wipe it off.
