HARDWARE ERROR:TRACK FOLLOWING ERROR
ggking7
#1 Post by ggking7 » Thu Jul 17, 2014 2:34 am
I'm using a Buffalo USB Blu-Ray drive with my laptop. Should I get a different one? Any recommendations?
Saving 1 titles into directory /home/user/Videos/The_Frighteners
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/50298.m2ts' at offset '1151582208'
Failed to save title 5 to file /home/user/Videos/The_Frighteners/The_Frighteners_t05.mkv
0 titles saved, 1 failed
Re: HARDWARE ERROR:TRACK FOLLOWING ERROR
#2 Post by Woodstock » Thu Jul 17, 2014 2:59 pm
Is it just that one disk giving you problems? There was another similar issue in this past week where the problem was the BD itself, not the drive.
ggking7
#3 Post by ggking7 » Thu Jul 17, 2014 4:10 pm
I've tried 2 discs and I had this issue with 1 of them. Could it be a problem with the combination of drive and disc?
#4 Post by Woodstock » Fri Jul 18, 2014 6:34 pm
If one disk works and another doesn't, it MOSTLY excludes the drive. However, a dual-layer disk can have tracking problems that a single-layer won't have, and the chance of a problem gets worse the more layers there are.
The key would be to test using another BD that has the same amount of data on it, so you know you're working with like-for-like. MakeMKV displays information on the number of layers on "Info" window, BEFORE you click on "open" or "backup". It looks like this:
Product: BDDVDRW UH08LS10
Revision: 2.00
Serial number: H9M9B395441
Firmware date: 2009-10-26 12:34:56
Highest AACS version: 47
Disc Information
Label: PROBLEM CHILDREN DISC 1
Timestamp: 2014-05-21 18:23:10
Data capacity: 34.61 Gb
Disc type: BD-ROM
Number of layers: 2
If it remains just the one disk that has the tracking problem, it's most likely damaged, and should be replaced (assuming it's new).
ggking7
#5 Post by ggking7 » Tue Jul 22, 2014 10:57 pm
Different drive, same title, different disc:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/50287.m2ts' at offset '3660183552'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/50287.m2ts' at offset '3668441088'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/50287.m2ts' at offset '3670339584'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/50287.m2ts' at offset '3675912192'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/50287.m2ts' at offset '3681810432'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/50287.m2ts' at offset '3682332672'
Failed to save title 6 to file /home/user/Videos/The_Frighteners/The_Frighteners_t06.mkv
