I am curious if my disc is bad or this is part of the copy protection. I have only experienced this on this particular bluray.
I see "snow" like a tv-signal with interference on the danish bluray "Kapringen". It still seems to play i full hd without any other problems. This also happens if I play directly from the disc via VLC.
There were no warnings or problems with ripping.
Snow on the screen
Re: Snow on the screen
Some movies use static over the video for "artsy" purposes. If playing the BD directly shows it, then the MKV file would show it, too.
