The Eagle (2011)
kharder2dk
The Eagle (2011)
Post by kharder2dk »
I get the following error when I try to rip The Eagle (Bluray).
DEBUG: Code 12720 at `8L%A!/uBQ! &#!T:121265522
DEBUG: Code 1 at Pi:F{G+H%FkB[9{`CK:29399427
DEBUG: Code 0 at Pi:F{G+H%FkB[9{`CK:29400324
Thank you, :)
kharder2dk
Re: The Eagle (2011)
Debug messages like that mean that MakeMKV is trying different work-arounds for problems it sees. If you do not see a "failed" message, the work-arounds worked.
If it did fail, copy and paste the full debugging log (assuming it is turned on, see my signature) in a reply. You can put it between "Code" tags (button above the reply box) so it stays separate from the text.
kharder2dk
I found the solution after reading the log. My dtsdecoderdll.dll was the wrong version.
Post by mike admin »
kharder2dk wrote:I found the solution after reading the log. My dtsdecoderdll.dll was the wrong version.
Was it "invalid" or "unknown" version? Can you please post the relevant log line?
kharder2dk
I do not have the log anymore, but it said something like: "dtsdecoderdll.dll needs to be at least version 10.1.0.5".
