The Eagle (2011)
kharder2dk
The Eagle (2011)
Post by kharder2dk » Tue Jul 15, 2014 8:12 pm
I get the following error when I try to rip The Eagle (Bluray).
DEBUG: Code 12720 at `8L%A!/uBQ! &#!T:121265522
DEBUG: Code 1 at Pi:F{G+H%FkB[9{`CK:29399427
DEBUG: Code 0 at Pi:F{G+H%FkB[9{`CK:29400324
Thank you, :)
kharder2dk
Re: The Eagle (2011)
Post by Woodstock » Tue Jul 15, 2014 8:54 pm
Debug messages like that mean that MakeMKV is trying different work-arounds for problems it sees. If you do not see a "failed" message, the work-arounds worked.
If it did fail, copy and paste the full debugging log (assuming it is turned on, see my signature) in a reply. You can put it between "Code" tags (button above the reply box) so it stays separate from the text.
kharder2dk
Post by kharder2dk » Tue Jul 15, 2014 9:28 pm
I found the solution after reading the log. My dtsdecoderdll.dll was the wrong version.
Post by mike admin » Wed Jul 16, 2014 9:26 am
kharder2dk wrote:I found the solution after reading the log. My dtsdecoderdll.dll was the wrong version.
Was it "invalid" or "unknown" version? Can you please post the relevant log line?
kharder2dk
Post by kharder2dk » Wed Jul 16, 2014 10:32 am
I do not have the log anymore, but it said something like: "dtsdecoderdll.dll needs to be at least version 10.1.0.5".
