The Eagle (2011)
kharder2dk
The Eagle (2011)
#1 Post by kharder2dk » Tue Jul 15, 2014 8:12 pm
I get the following error when I try to rip The Eagle (Bluray).
DEBUG: Code 12720 at `8L%A!/uBQ! &#!T:121265522
DEBUG: Code 1 at Pi:F{G+H%FkB[9{`CK:29399427
DEBUG: Code 0 at Pi:F{G+H%FkB[9{`CK:29400324
Thank you, :)
kharder2dk
Re: The Eagle (2011)
#2 Post by Woodstock » Tue Jul 15, 2014 8:54 pm
Debug messages like that mean that MakeMKV is trying different work-arounds for problems it sees. If you do not see a "failed" message, the work-arounds worked.
If it did fail, copy and paste the full debugging log (assuming it is turned on, see my signature) in a reply. You can put it between "Code" tags (button above the reply box) so it stays separate from the text.
kharder2dk
#3 Post by kharder2dk » Tue Jul 15, 2014 9:28 pm
I found the solution after reading the log. My dtsdecoderdll.dll was the wrong version.
#4 Post by mike admin » Wed Jul 16, 2014 9:26 am
kharder2dk wrote:I found the solution after reading the log. My dtsdecoderdll.dll was the wrong version.
Was it "invalid" or "unknown" version? Can you please post the relevant log line?
kharder2dk
#5 Post by kharder2dk » Wed Jul 16, 2014 10:32 am
I do not have the log anymore, but it said something like: "dtsdecoderdll.dll needs to be at least version 10.1.0.5".
