Smallville Season 6 (trouble ripping)
kimja215
I'm currently trying to rip Smallville Season 6 but it won't rip. Please help.
Re: Smallville Season 6 (trouble ripping)
Hint: "It doesn't work" makes it hard to help. Link in my signature will help us help you. You can post the log in your reply.
kimja215
Sorry about that. The first episodes on each disc won't rip. Maybe this might help.
MakeMKV v1.8.10 darwin(x86-release) started
Optical drive "DVD+R-DL HL-DT-ST DVDRW GX30N RP09d" opened in OS access mode.
The new version 1.8.11 is available for download at /download/
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Calculated BUP offset for VTS #6 does not match one in IFO header.
Calculated BUP offset for VTS #7 does not match one in IFO header.
Calculated BUP offset for VTS #8 does not match one in IFO header.
Title #1 was added (7 cell(s), 0:42:13)
Title #1/0/1 was added (7 cell(s), 0:42:07)
Title #1/0/2 was added (7 cell(s), 0:40:19)
Cells 8-end were skipped due to cell commands (structure protection?)
Title #2 was added (7 cell(s), 0:42:13)
Title #3 was added (7 cell(s), 0:42:07)
Title #4 was added (7 cell(s), 0:40:19)
Title #11 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/1 has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/2 has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13/1 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #16 was added (6 cell(s), 0:22:28)
Title #17 was added (1 cell(s), 0:03:31)
Title #18 was added (1 cell(s), 0:03:43)
Title #19 was added (1 cell(s), 0:02:59)
Title #20 was added (1 cell(s), 0:03:15)
Title #21 was added (1 cell(s), 0:04:35)
Title #22 was added (1 cell(s), 0:04:25)
Title #23 was added (3 cell(s), 0:09:08)
Title #24 was added (1 cell(s), 0:02:52)
Title #25 was added (1 cell(s), 0:03:45)
Title #26 was added (1 cell(s), 0:02:31)
Title #27 was added (5 cell(s), 0:09:50)
Title #28 has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #29 has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #30 has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #31 has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #32 was added (1 cell(s), 0:02:18)
Title #33 was added (2 cell(s), 0:02:22)
Title #34 has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #35 has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 2 in VTS 1 is equal to title 1 and was skipped
Title 3 in VTS 1 is equal to title 1 and was skipped
Title 4 in VTS 1 is equal to title 1 and was skipped
Saving 1 titles into directory /Users/kimj469/Desktop
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '989184'
You probably should update to 1.8.11, but that doesn't look to be the problem here. This is:
The drive says it can't read part of the disk. Things you can try:
Clean the disk. Yes, it may look clean, but there can be minor scratches that will interfere with the laser. I clean with spray furniture polish (Pledge brand works), because it cuts fingerprints, and fills in minor scratches. Soft cloth! I have special cotton towels I keep clean for that purpose, but others use cotton T-shirt scraps.
Increase the number of retries. Tools->IO, the default is 5. This tells MakeMKV to ask the operating system to try more times. Sometimes, it helps.
If you have a different disk drive, try it. The lasers in different drives have slightly different alignments; I have 3 BD and 4 DVD drives of various vintages for when the main ones can't read.
Sometimes, the disk is just bad. I had to get one disk replaced twice before it was readable, because the first two were from a batch with problems.
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '989184'Clean the disk. Yes, it may look clean, but there can be minor scratches that will interfere with the laser. I clean with spray furniture polish (Pledge brand works), because it cuts fingerprints, and fills in minor scratches. Soft cloth! I have special cotton towels I keep clean for that purpose, but others use cotton T-shirt scraps.
baileymb124
10 years after this thread started, I am now having the same issue.
Do you have a drive or drives that you'd suggest? My media server has a DVD drive, but I need to purchase a Blu-Ray Drive. If I could get a Blu-Ray Drive that is ALSO able to read this DVD, that would be great...
Thanks in advance.
Thanks in advance.
mrswadge
I had trouble with Disc 1 (episode 3) and Disc 2 (episode 6). All other episodes were fine. I tried EaseFab and it read it fine. I think it's a weakness in MakeMKV unfortunately.
mrswadge
I'm going to correct my above assertion. EaseFab cut out 10 minutes of video from Disc 1 - Episode 3, so I think actually my disks are wrecked
