Lego Movie Fails
dvdlovr24
Lego Movie Fails
Post by dvdlovr24 »
I have tried twice now and keep getting this same error:
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00098.m2ts' at offset '7932801024'
DEBUG: Code 0 at C)$6\>^]9J)#GfhSo\8W:121263038
DEBUG: Code 0 at ct,X;4<lhpgG-Z7q8^{2:121261888
DEBUG: Code 0 at C)$6\>^]9J)#GfhSo\8W:213130559
DEBUG: Code 3873438 at C)$6\>^]9J)#GfhSo\8W:29393286
DEBUG: Code 0 at |g*pv%G|,R+"H#Kc:'$A9:213135090
Ideas?
Re: Lego Movie Fails
Your drive cannot read the disk. The error indicates a problem with the servo mechanism in it, or a disk that is so badly flawed that the drive cannot adjust to where the track goes.
dvdlovr24
Post by dvdlovr24 »
I guess it must be a bad disc then because it ripped Grand Budapest Hotel with no issues. I'll try swapping it out to see if that fixes it. Thanks!
vondur
Post by vondur »
I'm pretty sure it's a bad/dirty disk. I was able to rip it just fine.
