Cannot customize subtitles in dune player
berdel
Post by berdel »
I have problems with changing the size of subtitles when the rip is made with MakeMKV. The size does not change as it does with .srt files.
I really wish that there was a way so that all subtitles could be presented similar, in size and location.
Anyone know a tip on how to fix that?
Chetwood
Re: Cannot customize subtitles in dune player
Post by Chetwood »
BD subs are bitmap images. I'm not aware of any standalone that allows to change those. If you want to be able to, you need to OCR them into SRT subs which IMO isn't worth the effort.
berdel
Post by berdel »
Ok, I guess i will just have to live with the original subtitles then
thanks a lot
