Errors with Casse t?te chinois (French movie)
cameleon078
Post by cameleon078 » Wed Jul 09, 2014 6:03 pm
Please find makemkv errors below :
Debug log started at Wed Jul  9 16:47:45 2014 , written by MakeMKV v1.8.11 linux(x64-release)
001005:0000 MakeMKV v1.8.11 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/samuel/MakeMKV_log.txt
003025:0000 Title #2 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #3 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #5 was added (4 cell(s), 0:52:30)
003028:0000 Title #6 was added (2 cell(s), 0:25:16)
003025:0000 Title #7 has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 2 at <[AFVZJdmx\{1cIW:213137827
003028:0000 Title #8 was added (19 cell(s), 1:55:02)
003028:0000 Title #9 was added (1 cell(s), 0:03:35)
003025:0000 Title #10 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #11 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #12 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=8 pgcn=1 hash=79EEAE47BE54B0C3
Title skip vts=9 pgcn=2 hash=D69C1492FE50D163
003028:0000 Title #15 was added (16 cell(s), 1:32:22)
001003:0020 DEBUG: Code 10551311 at 7Y.C-h=r.,nX6!m~:121273595
001003:0020 DEBUG: Code 0 at 7Y.C-h=r.,nX6!m~:121274216
001003:0020 DEBUG: Code 0 at 3Ev.4+jt!w)K`pna)-:29394390
003035:0000 CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
003037:0000 Cells 1-1 were removed from title start
003038:0000 Cells 15-15 were removed from title end
003028:0000 Title #16 was added (13 cell(s), 1:52:27)
003028:0000 Title #17 was added (19 cell(s), 1:55:02)
003028:0000 Title #18 was added (13 cell(s), 1:52:27)
003028:0000 Title #19 was added (13 cell(s), 1:52:27)
003028:0000 Title #20 was added (19 cell(s), 1:55:02)
003028:0000 Title #21 was added (14 cell(s), 1:14:30)
003028:0000 Title #22 was added (14 cell(s), 1:14:30)
Title skip vts=3 pgcn=1 hash=9803F6B73823572B
003028:0000 Title #24 was added (18 cell(s), 1:53:30)
Title skip vts=20 pgcn=1 hash=8EBDA96839DF88FB
Title skip vts=21 pgcn=1 hash=00700BA0945DB19C
Title skip vts=22 pgcn=1 hash=B208C78A45E71869
Title skip vts=23 pgcn=1 hash=2EFF12D74C5CB182
003028:0000 Title #29 was added (17 cell(s), 1:42:59)
003028:0000 Title #30 was added (18 cell(s), 1:54:39)
003027:0000 Title 1 in VTS 13 is equal to title 1 and was skipped
003027:0000 Title 1 in VTS 11 is equal to title 1 and was skipped
003027:0000 Title 1 in VTS 16 is equal to title 1 and was skipped
005014:0000 Saving 1 titles into directory /home/samuel/Vid?os/DVDs/_CASSE_TETE_CHINOIS_E547
001003:0020 DEBUG: Code 1073741829 at df5;HQYD(q"4#eq.:29393953
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_13_1.VOB' at offset '16590848'
001003:0020 DEBUG: Code 0 at eH($%B2_#w?{L<GW]Sq::121263038
001003:0020 DEBUG: Code 0 at }FZTQmw#3mNk5#-9llf:121261750
001003:0020 DEBUG: Code 0 at eH($%B2_#w?{L<GW]Sq::213130559
001003:0020 DEBUG: Code 8101 at eH($%B2_#w?{L<GW]Sq::29393286
001003:0020 DEBUG: Code 0 at =c>#8%@-Dp}#}vygR-H3B:213135090
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
005003:0000 Failed to save title 2 to file /home/samuel/Vid?os/DVDs/_CASSE_TETE_CHINOIS_E547/title02.mkv
005004:0080 0 titles saved, 1 failed
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_11_1.VOB' at offset '738756608'
001003:0020 DEBUG: Code 360721 at eH($%B2_#w?{L<GW]Sq::29393286
005003:0000 Failed to save title 5 to file /home/samuel/Vid?os/DVDs/_CASSE_TETE_CHINOIS_E547/title05.mkv
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_19_1.VOB' at offset '16590848'
005003:0000 Failed to save title 7 to file /home/samuel/Vid?os/DVDs/_CASSE_TETE_CHINOIS_E547/title07.mkv
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_24_1.VOB' at offset '16590848'
005003:0000 Failed to save title 8 to file /home/samuel/Vid?os/DVDs/_CASSE_TETE_CHINOIS_E547/title08.mkv
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_18_1.VOB' at offset '16590848'
005003:0000 Failed to save title 9 to file /home/samuel/Vid?os/DVDs/_CASSE_TETE_CHINOIS_E547/title09.mkv
003028:0000 Title #8 was added (18 cell(s), 1:54:39)
003028:0000 Title #15 was added (15 cell(s), 1:31:59)
003028:0000 Title #17 was added (18 cell(s), 1:54:39)
003028:0000 Title #20 was added (18 cell(s), 1:54:39)
003028:0000 Title #21 was added (13 cell(s), 1:14:07)
003028:0000 Title #22 was added (13 cell(s), 1:14:07)
003028:0000 Title #24 was added (17 cell(s), 1:53:07)
003028:0000 Title #29 was added (16 cell(s), 1:42:36)
003027:0000 Title 2 in VTS 13 is equal to title 1 and was skipped
003032:0000 Region setting of drive HL-DT-ST:BD-RE  BH16NS40 does not match the region of currently inserted disc, trying to work around...
DEBUG: Code 0 at 3"|-26F3ban"0OMY :213130283
DEBUG: Code 0 at 3"|-26F3ban"0OMY :213133250
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16590848, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16592896, attempting to work around
001003:0020 DEBUG: Code 0 at -vL&IwN}I:C<^SSc:29396529
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading '/VIDEO_TS/VTS_13_1.VOB' at offset '16742400'
001003:0020 DEBUG: Code 8175 at eH($%B2_#w?{L<GW]Sq::29393286
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16594944, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16596992, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16599040, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16601088, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16603136, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16605184, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16607232, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16609280, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16611328, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16613376, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16615424, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16617472, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16619520, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16621568, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16623616, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16625664, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16627712, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16629760, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16631808, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16633856, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16635904, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16637952, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16640000, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16642048, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16644096, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16646144, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16648192, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16650240, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16652288, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16654336, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16656384, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16658432, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16660480, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16662528, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16664576, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16666624, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16668672, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16670720, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16672768, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16674816, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16676864, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16678912, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16680960, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16683008, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16685056, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16687104, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16721920, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16723968, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16726016, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16728064, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16730112, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16732160, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16734208, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16736256, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16738304, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16740352, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16742400, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16744448, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16746496, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16748544, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16750592, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16752640, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16754688, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16756736, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16758784, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16760832, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16762880, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16764928, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16766976, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16769024, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16771072, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16773120, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16775168, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16777216, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16779264, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16781312, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16783360, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16785408, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16787456, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16789504, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16791552, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16793600, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16795648, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16797696, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16799744, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16801792, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16803840, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16805888, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16807936, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16809984, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16812032, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16814080, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16816128, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16818176, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16820224, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16822272, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16824320, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16826368, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16828416, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16830464, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16832512, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16834560, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16836608, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16838656, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16840704, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16842752, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16844800, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16846848, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16848896, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16850944, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16852992, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16855040, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16857088, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16859136, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16861184, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16863232, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16865280, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16867328, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16869376, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16871424, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16873472, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16875520, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16877568, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16879616, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16881664, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16883712, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16885760, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16887808, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16889856, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 16891904, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 17276928, attempting to work around
001003:0020 DEBUG: Code 368 at PnW\7s+VcuSf*tYZ9/g:29398392
004007:0010 AV synchronization issues were found in file '/home/samuel/Vid?os/DVDs/_CASSE_TETE_CHINOIS_E547/title02.mkv' (title #3)
004008:0010 AV sync issue in stream 1 at 0:00:22.368 with duration of 1088ms : audio gap - 34 missing frame(s)
001003:0020 DEBUG: Code 1201 at =c>#8%@-Dp}#}vygR-H3B:29393631
001003:0020 DEBUG: Code 1202 at =c>#8%@-Dp}#}vygR-H3B:29393631
001003:0020 DEBUG: Code 1203 at =c>#8%@-Dp}#}vygR-H3B:29393631
001003:0020 DEBUG: Code 1204 at =c>#8%@-Dp}#}vygR-H3B:29393631
001003:0020 DEBUG: Code 1205 at =c>#8%@-Dp}#}vygR-H3B:29393631
001003:0020 DEBUG: Code 1206 at =c>#8%@-Dp}#}vygR-H3B:29393631
001003:0020 DEBUG: Code 1207 at =c>#8%@-Dp}#}vygR-H3B:29393631
001003:0020 DEBUG: Code 1467 at 56yUq, rT'|>=o r:121266051
001003:0020 DEBUG: Code 1 at 56yUq, rT'|>=o r:121263751
004008:0010 AV sync issue in stream 1 at 0:00:23.776 with duration of 961.211ms : audio gap - 30.037 missing frame(s)
Application exited at Wed Jul  9 17:24:59 2014
Thanks in advance.
Regards.
cameleon078
Re: Errors with Casse t?te chinois (French movie)
Post by cameleon078 » Thu Jul 17, 2014 1:44 pm
Any answer on this topic ?
Regards.
Post by Woodstock » Thu Jul 17, 2014 2:55 pm
The errors are marked as such:
Your drive cannot read parts of the disk. Which beget the problems with corrupt files:
