Hi, I have a bluray with a KDM folder containing .bin file. The regular .m2ts files are quite small while one of the .bin is quite large. If I remux the Bluray with makemkv I only get a few minutes long movie.
Any idea about how to proceed with such bluray (Japanese movie) ?
Thanks.
BluRay with KDM folder and .bin files
- Contact:
Re: BluRay with KDM folder and .bin files
Can you play it on a regular blu-ray player? It appears to be an encrypted DCP master, not a regular blu-ray disc.
download4004
I can play it with MPC-HC. Is there a way to change the structure so that I can use MAKEMKV to remux it ?
MAKEMKV works but only extracts a small file, as if the .bin are not decoded I guess.
It is a so called MGVC bluray (Japan)
- Contact:
What are you selecting? Just the folder, or one of the BIN files?download4004 wrote:I can play it with MPC-HC.
Please make a full disc backup of this disc with MakeMKV. Then, from this backup please copy CLIPINF and PLAYLIST folders with all files inside, compress, and send to support@makemkv.com . Please keep the backup on disc for further analysis.download4004 wrote:It is a so called MGVC bluray (Japan)
download4004
Thanks for your reply
I will do and post it.
Is there an update to this? i also have problems with a bluray structured with MGVC files
Also, here is some more detail on these discs
http://www.avsforum.com/forum/114-hdtv- ... japan.html
For those wondering, the link posted in previous post, most likely should lead here today: https://www.avsforum.com/threads/36-bit ... n.1486405/
