The Bridge, season one, TimecodeDelay exceptions
bernard
Post by bernard » Tue Mar 11, 2014 1:35 am
No titles saved. Here's the log:
MakeMKV v1.8.9 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Bernard/MakeMKV_log_1.txt
[deleted lines about "Operation was cancelled."]
File 00007.mpls was added as title #0
File 00006.mpls was added as title #1
File 00005.mpls was added as title #2
File 00004.mpls was added as title #3
File 00003.mpls was added as title #4
File 00002.mpls was added as title #5
Title #00001.mpls has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.mpls(1) has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 6 titles into directory //  /Movies/The Bridge/Disc 1 using profile 'FLAC' from file 'C:\Program Files (x86)\MakeMKV/flac.mmcp.xml'
LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
Failed to save title 0 to file //   /Movies/The Bridge/Disc 1/The_Bridge_Disc_1_t00.mkv
Failed to save title 1 to file //   /Movies/The Bridge/Disc 1/The_Bridge_Disc_1_t01.mkv
Failed to save title 2 to file //   /Movies/The Bridge/Disc 1/The_Bridge_Disc_1_t02.mkv
Failed to save title 3 to file //   /Movies/The Bridge/Disc 1/The_Bridge_Disc_1_t03.mkv
Failed to save title 4 to file //   /Movies/The Bridge/Disc 1/The_Bridge_Disc_1_t04.mkv
Failed to save title 5 to file //   /Movies/The Bridge/Disc 1/The_Bridge_Disc_1_t05.mkv
0 titles saved, 6 failed
Re: The Bridge, season one, TimecodeDelay exceptions
Post by mike admin » Thu Mar 13, 2014 7:37 am
Please send a testdump per instructions at /onlinehelp/testdump.html
bernard
Post by bernard » Fri Jul 04, 2014 12:46 am
mike admin wrote:Please send a testdump per instructions at /onlinehelp/testdump.html
Any word on this? Thanks.
Post by mike admin » Fri Jul 04, 2014 7:01 am
Didi it work with 1.8.11 ?
