1408 Failure
enilsen
1408 Failure
Post by enilsen » Thu Jul 03, 2014 9:34 pm
Hello everyone, hoping someone has had a similar issue and may have a solution out there.
I have tried this on Linux / windows, multiple versions of makemkv and now 2 physical copies of the movie.
It keeps erroring out at the same place.
Saving 1 titles into directory D:/Video/1408
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00142.m2ts' at offset '18965594112'
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00142.m2ts' at offset '18965594112'
DEBUG: Code 0 at !,+mNdHPXD/q|[j%Otd+:121263038
DEBUG: Code 0 at NKffz|Yk#yfOdimp%6`l:121261888
DEBUG: Code 0 at !,+mNdHPXD/q|[j%Otd+:213130559
DEBUG: Code 9260544 at !,+mNdHPXD/q|[j%Otd+:29393286
DEBUG: Code 0 at ){&>x>,?^(N$Rt<WLL~o@:213135090
DEBUG: Code 0 at 59]d<n;a!kuNR@(5K(!:29396621
DEBUG: Code 1 at 59]d<n;a!kuNR@(5K(!:121270053
DEBUG: Code 0 at 59]d<n;a!kuNR@(5K(!:121266465
DEBUG: Code 0 at qY:TN+n3hR8:&B][F:213131893
DEBUG: Code 0 at qY:TN+n3hR8:&B][F:121263406
DEBUG: Code 0 at qY:TN+n3hR8:&B][F:29393907
Failed to save title 1 to file D:/Video/1408/title01.mkv
0 titles saved, 1 failed
Re: 1408 Failure
Post by Woodstock » Fri Jul 04, 2014 3:22 am
Your drive says it can't read part of the disk. Cleaning the disk is your first step. Personally, I clean disks with Pledge furniture polish, because it waxes at the same time, which helps with some disks.
There is a chance that the disks themselves are mastered poorly... which would explain multiple disks failing at the SAME place.
