Bluray failed
gunny58
Bluray failed
Post by gunny58 »
I'm running Linux Mint 17, MakeMKV 1.8.11 beta. DVD's are working fine. But the BD's are always failing.
OS device name: /dev/sr1
Manufacturer: MATSHITA
Product: BD-MLT UJ260AF
Revision: 1.00
Serial number: WQ00 023395
Highest AACS version: 33
Disc Information
Label: MAENNER
Timestamp: 2012-08-01 10:42:42
Data capacity: 21.59 Gb
Disc type: BD-ROM
Number of layers: 1
And this are the results of the logfile:
DEBUG: Code 0 at 3"|-26F3ban"0OMY :213130559
DEBUG: Code 0 at :)j&@ZuY"vnO%Y*q>4:29395218
DEBUG: Code 0 at :)j&@ZuY"vnO%Y*q>4:29394643
DEBUG: Code 1 at :)j&@ZuY"vnO%Y*q>4:29394643
DEBUG: Code 2 at :)j&@ZuY"vnO%Y*q>4:29394643
DEBUG: Code 3 at :)j&@ZuY"vnO%Y*q>4:29394643
DEBUG: Code 4 at :)j&@ZuY"vnO%Y*q>4:29394643
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..0800024C0 to device 'SG:dev_11:1'
DEBUG: Code 0 at :)j&@ZuY"vnO%Y*q>4:121264487
Highest AACS version is v33 , MKB saved as /home/ln/.MakeMKV/MKB_v33_MAENNER.tgz
DEBUG: Code 0 at :PT9V/BI5.d4Ul,#:213131962
DEBUG: Code 0 at :PT9V/BI5.d4Ul,#:29397357
For you I switched MakeMKV to english language. Normally I run it in German. I tried different BD's. Always the same log. The only difference in the logs is the version of AACS (17 / 33 / 47)
Can you help me?
gunny58
Re: Bluray failed
Post by gunny58 »
Nobody an idea?
Re: Bluray failed
Only the author (Mike) can decode the debugging messages, and he isn't here every day.
gellis
Re: Bluray failed
Post by gellis »
Very interesting!
You have the same drive as me - I get the same errors :(
