Error backing up discs with Pioneer BDR-XD05W External Drive
rshackleford
Post by rshackleford »
Greetings,
MakeMKV starts to analyze the disc and when it has finished, it exits with a fatal error. This happens on regular DVDs as well so I think it has an issue recognizing my drive fully. In previous versions it was said to delete a couple of dll files (libdriveio.dll and libdriveio64.dll) and replace them. Those files are no longer available but I'm sure they wouldn't work anyway (this was related to a version 1.6.6 problem of the same kind). Does anyone have a fix for this? I don't want to buy the program if I can't backup my discs. I'd like to avoid buying a different drive in case it happens with that one as well (I just bought the Pioneer one today).
Re: Error backing up discs with Pioneer BDR-XD05W External D
Would certainly help to have some information to go on.... Please turn on debug logging and post the debug log in a reply. That will HOPEFULLY have some information on the errors being encountered.
