0 titles saved 1 failed - FIXED
madcow1
#1 Post by madcow1 » Thu Feb 25, 2010 9:04 pm
I apologize if I should post this in the titles that have not worked thread, but this may be system specific. In trying to rip the Blue Man Group Blu Ray I can get all titles except the main title. The output from Make MKV is below.
Additionally, I ripped Kung Fu Panda before lossless HD audio tracks were available and I decided to re-rip it with lossless audio. When I atempted this, I got a similar error to the Blue Man Group disc; all titles would copy except the main movie file. In that case I decided to just keep my original MKV w/o HD audio.
The Blue Man disc is clean and scratchless and plays in Arcsoft TMT in media center just fine.
Any ideas?
Here is the output:
MakeMKV v1.4.12 beta win(x64-release) started
Evaluation version, 10 day(s) out of 30 remaining
File 00014.mpls was added as title #0
File 00026.mpls was added as title #1
Title #00019.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00025.m2ts was added as title #2
File 00026.m2ts was added as title #3
File 00027.m2ts was added as title #4
Title #00028.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Operation sucessfully completed
Saving 1 titles into directory G:/Video/BLUE_MAN_GROUP
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occured while reading '/BDMV/STREAM/00024.m2ts' at offset '16007233536'
Error 'Scsi error - MEDIUM ERROR:1090' occured while reading '/BDMV/STREAM/00024.m2ts' at offset '16007233536'
Failed to save title 1 to file G:/Video/BLUE_MAN_GROUP/title01.mkv
0 titles saved, 1 failed
madcow1
Re: 0 titles saved 1 failed
#2 Post by madcow1 » Sat Feb 27, 2010 12:04 am
Looks like I solved the problem by changing the read retry count from 5 to 15 (under preferences - IO)
