Scsi error
jettajack
Scsi error
Post by jettajack » Mon Jun 30, 2014 3:45 pm
I'm not a complete newbie and I've been able to work through most problems, but I wanted to make sure I'm correct in my assumption that this is a disk error. I'm trying to rip The Hobbit: An Unexpected Journey and I'm getting the following debug report:
Debug log started at Mon Jun 30 15:22:05 2014 , written by MakeMKV v1.8.11 darwin(x86-release)
001005:0000 MakeMKV v1.8.11 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/marlastout/MakeMKV_log.txt
002014:0000 Optical drive "BD-ROM hp BDDVDRW CT10L YC09" opened in DASPI v1.4 mode.
DAFD=PAAAADAAAAEABDQUEAQEEAQ==
DCE=zm7y0KaheOzokUIbe0QVArqo4kmICmUrXgTnqgY42Ywoq2vJJpKD7VVohw+afmAQ+P5DAg8mhtM2589lYAt20ppWL8mkfWzGqLNjkauogjVhLgvVFB4EisFeOxkNG8aJnWiBdtAHXvPBXgpBhBg2CdDkW+dGrREmBg==
DISCID=74FE9D1998C464AE3D46E7038DD9F762C7942DBF
003307:0000 File 00100.mpls was added as title #0
003025:0000 Title #00009.mpls has length of 50 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00120.mpls has length of 90 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00007.mpls has length of 340 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00008.mpls has length of 29 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00000.mpls has length of 8 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 395 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 11 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 5 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00999.m2ts has length of 4 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 4 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 50 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 45 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 1 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 340 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 6 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00901.m2ts has length of 15 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00900.m2ts has length of 15 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 45 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00023.m2ts has length of 4 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 4 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 29 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 23 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Users/marlastout/Movies/The_Hobbit_An_Unexpected_Journey
001003:0020 DEBUG: Code 1073741829 at &:ScxH-S}++RkDH[:29393953
001003:0020 DEBUG: Code 2 at UK>27R`LGO6tpM5Z:213137827
002003:0000 Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '1110964224'
002003:0000 Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '1110964224'
002003:0000 Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '1110976512'
001003:0020 DEBUG: Code 0 at C)$6\>^]9J)#GfhSo\8W:121263038
001003:0020 DEBUG: Code 0 at ct,X;4<lhpgG-Z7q8^{2:121261888
001003:0020 DEBUG: Code 0 at C)$6\>^]9J)#GfhSo\8W:213130559
001003:0020 DEBUG: Code 542469 at C)$6\>^]9J)#GfhSo\8W:29393286
001003:0020 DEBUG: Code 0 at |g*pv%G|,R+"H#Kc:'$A9:213135090
005003:0000 Failed to save title 0 to file /Users/marlastout/Movies/The_Hobbit_An_Unexpected_Journey/The_Hobbit_An_Unexpected_Journey_t00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Mon Jun 30 15:33:29 2014
Is this a bad disk? I've cleaned it and it looks perfect, so I'm a bit confused.
Thanks for the help.
Re: Scsi error
Post by Woodstock » Mon Jun 30, 2014 8:36 pm
The drive seems to think it is bad, but that can sometimes be a bit of fluff blowing by the laser at the wrong moment. Mike will have to review the debug messages to see if they're showing a problem.
