Hi
Im considering to buy makemkv, but how many computers can use the same key? Am i forced to buy multiple keys?
Also is the price going up or down later on?
Currently the price is 50 euro.
Buying makemkv
Re: Buying makemkv
Price covers one user at a time, which means you can install it on 12 computers or 1, and use it on any one of them.
Mike set the price at USD50. The company handling the order processing adjusts that to cover currency transfer and whatever. I doubt that Mike would change it, but it is his program, he can price it wherever he feels like it.
Zlaxhe
Re: Buying makemkv
Tanks for information
Im just curious if makemkvs price is going to change when the beta period is over
I know he can change it when he wants but i dont think hes going to do that out of nowhere..
Devore
Re: Buying makemkv
No one knows when the beta period will be over, if ever.
If you want to pay price in USD, which I think always works out the cheapest (it's like $80 CDN), you can use a US-based HTTP/S web proxy to make your purchase, as currency selection is hardwired based on geolocation.
Zlaxhe
Re: Buying makemkv
Just bought it to support the developer
