color of night
Reddz144
color of night
#1 Post by Reddz144 » Wed Jun 25, 2014 11:29 pm
Thought i had a bad dvd but second one samething help please.
Saving 1 titles into directory E:/Media/Movies/Color Of Night (1994)
DEBUG: Code 449 at 59]d<n;a!kuNR@(5K(!:29399404
DEBUG: Code 0 at ){&>x>,?^(N$Rt<WLL~o@:213135090
DEBUG: Code 0 at qY:TN+n3hR8:&B][F:213131893
DEBUG: Code 0 at qY:TN+n3hR8:&B][F:121263406
DEBUG: Code 0 at qY:TN+n3hR8:&B][F:29393907
Failed to save title 0 to file E:/Media/Movies/Color Of Night (1994)/title00.mkv
0 titles saved, 1 failed
Re: color of night
#2 Post by Woodstock » Thu Jun 26, 2014 2:27 am
Do you have the rest of the debug log? It would contain more information about the problem, including the version of MakeMKV you're using and about the scanning of the disk.
(if you don't have debug logging enabled, see the FAQ linked in my signature)
Reddz144
Re: color of night
#3 Post by Reddz144 » Thu Jun 26, 2014 9:41 pm
MakeMKV v1.8.11 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Alden/MakeMKV_log.txt
DEBUG: Code 134219780 at IPzDgi*,*/jt?q]vG:121261957
DEBUG: Code 0 at IPzDgi*,*/jt?q]vG:121263774
Drive BD-ROM ATAPI iHES112 3 ML04 has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
Title #1 was added (28 cell(s), 2:18:51)
Angle #2 was added for title #1
Title #2 has length of 124 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Re: color of night
#4 Post by mike admin » Fri Jun 27, 2014 9:38 am
Please send the full log file ( C:\Users\Alden/MakeMKV_log.txt ) to support@makemkv.com . Thank you.
Reddz144
Re: color of night
#5 Post by Reddz144 » Sat Jun 28, 2014 12:48 am
Looked several times i only see C:\Users\Alden/MakeMKV_log....not with the txt at the end.
and it has about a million characters in it.
Reddz144
Re: color of night
#6 Post by Reddz144 » Wed Jul 16, 2014 10:09 pm
Thanks to woodstock i was able to send the entire log to you mike
Reddz144
Re: color of night
#7 Post by Reddz144 » Fri Nov 28, 2014 5:37 pm
:D :D Thanks mike version 9 did it :D :D
