Convert LPCM audio tracks while leaving DTS tracks intact?
mattias83
Post by mattias83 » Fri Jun 20, 2014 8:06 pm
Is there a way to convert LPCM audio tracks to flac while keeping the DTS-HD or Dolby TrueHD tracks intact? I know I can select the flac profile but then it wants to convert all audio tracks to flac. Many blu-ray discs have LPCM and DTS tracks on the same disc and I would like to convert the LPCM tracks while leaving the DTS tracks alone.
ndjamena
Re: Convert LPCM audio tracks while leaving DTS tracks intac
Post by ndjamena » Fri Jun 20, 2014 9:29 pm
Edit the profile.
mattias83
Post by mattias83 » Sat Jun 21, 2014 2:27 am
So there is a way then. But I have no experience editing the profile. How would I do that?
I was hoping there was an easy way, like right-clicking on each audio track and selecting whether to convert or not.
ndjamena
Post by ndjamena » Sat Jun 21, 2014 3:26 am
Save this as pcmflac.mmcp.xml in your MakeMKV directory and then select the PCM->FLAC profile in the program (or set it as default as may be).
<?xml version="1.0" encoding="utf-8"?>
<profile>
    <!-- profile name - Default -->
    <name lang="eng">PCM->FLAC</name>
    <!-- Common MKV flags -->
    <mkvSettings
        ignoreForcedSubtitlesFlag="true"
        useISO639Type2T="false"
        setFirstAudioTrackAsDefault="true"
        setFirstSubtitleTrackAsDefault="false"
        setFirstForcedSubtitleTrackAsDefault="true"
        insertFirstChapter00IfMissing="true"
    <!-- Settings overridable in preferences -->
    <profileSettings
        app_DefaultSelectionString="-sel:all,+sel:(favlang|nolang),+sel:lossless,-sel:(havemulti|havelossless),-sel:mvcvideo,=100:all,-10:favlang"
    <!-- Output formats currently supported by MakeMKV -->
	<!-- Direct Copy -->
    <outputSettings name="copy" outputFormat="directCopy">
        <description lang="eng">Copy track as is</description>
    </outputSettings>
	<!-- PCM Output -->
    <outputSettings name="lpcm" outputFormat="LPCM-raw">
        <description lang="eng">Save as raw LPCM</description>
    </outputSettings>
    <outputSettings name="wavex" outputFormat="LPCM-wavex">
        <description lang="eng">Save as LPCM in WAV container</description>
    </outputSettings>
	<!-- FLAC Encoding -->
    <outputSettings name="flac-fast" outputFormat="FLAC">
        <description lang="eng">Save as FLAC (fast compression)</description>
        <extraArgs>-compression_level 5</extraArgs>
    </outputSettings>
    <outputSettings name="flac-best" outputFormat="FLAC">
        <description lang="eng">Save as FLAC (best compression)</description>
        <extraArgs>-compression_level 12</extraArgs>
    </outputSettings>
    <outputSettings name="flac-placebo" outputFormat="FLAC">
        <description lang="eng">Save as FLAC (placebo compression)</description>
        <extraArgs>-compression_level 12 -lpc_coeff_precision 15 -lpc_passes 8 -lpc_type 3</extraArgs>
    </outputSettings>
	<!-- Subtitle Compression -->
    <outputSettings name="copyzlib" outputFormat="directCopy">
        <description lang="eng">Copy track as is (zlib compressed)</description>
        <mkvTrackSettings compression="zlib" compressionLevel="9" />
    </outputSettings>
	<!-- AAC Encoding -->
    <outputSettings name="aac" outputFormat="AAC">
        <description lang="eng">Save as Mpeg-4 AAC-LC</description>
        <extraArgs>codec=libfdk_aac profile=LC</extraArgs>
        <extraArgs>afterburner=1</extraArgs>
    </outputSettings>
    <outputSettings name="he-aac" outputFormat="AAC">
        <description lang="eng">Save as Mpeg-4 HE-AAC</description>
        <extraArgs>codec=libfdk_aac profile=HE-AAC signaling=explicit_sbr</extraArgs>
    </outputSettings>
    <!-- stereo inputs only -->
    <outputSettings name="he-aacv2" outputFormat="AAC">
        <description lang="eng">Save as Mpeg-4 HE-AACv2</description>
        <extraArgs>codec=libfdk_aac profile=HE-AACv2 signaling=explicit_hierarchical</extraArgs>
    </outputSettings>
    <outputSettings name="aac-gpl" outputFormat="AAC">
        <description lang="eng">Save as Mpeg-4 AAC-LC (ffmpeg encoder)</description>
        <extraArgs>codec=aac -strict -2</extraArgs>
        <extraArgs>aac_coder=twoloop</extraArgs>
    </outputSettings>
	<!-- AC3 Encoding -->
    <outputSettings name="AC3-192" outputFormat="AC3">
        <description lang="eng">Save as AC3 (192kbps)</description>
		<extraArgs>-b 192k</extraArgs>
    </outputSettings>
    <outputSettings name="AC3-224" outputFormat="AC3">
        <description lang="eng">Save as AC3 (224kbps)</description>
		<extraArgs>-b 224k</extraArgs>
    </outputSettings>
    <outputSettings name="AC3-448" outputFormat="AC3">
        <description lang="eng">Save as AC3 (448kbps)</description>
		<extraArgs>-b 448k</extraArgs>
    </outputSettings>
    <outputSettings name="AC3-640" outputFormat="AC3">
        <description lang="eng">Save as AC3 (640kbps)</description>
		<extraArgs>-b 640k</extraArgs>
    </outputSettings>
    <!-- Audio downmix settings -->
    <audioMixSettings name="stereo16"
        outputBPS="16"
        outputChannelLayout="stereo"
        mix="DolbyPrologic2">
        <description lang="eng">Stereo 16-bit Dolby PrologicII downmix</description>
    </audioMixSettings>
    <audioMixSettings name="stereo16raw"
        outputBPS="16"
        centerMixLevel="-3dB"
        surroundMixLevel="-6dB"
        lfeMixLevel="0">
        <description lang="eng">Stereo 16-bit downmix</description>
    </audioMixSettings>
    <audioMixSettings name="16B51"
        outputBPS="16"
        outputChannelLayout="5.1">
        <description lang="eng">6.1 DTS-MA to 16-bit 5.1 (For WDTV Live SMP)</description>
    </audioMixSettings>
    <!-- Default rule - copy as is -->
    <trackSettings input="default">
        <output outputSettingsName="copy"
                defaultSelection="$app_DefaultSelectionString">
        </output>
    </trackSettings>
    <!-- Save LPCM mono or stereo as FLAC -->
    <trackSettings input="LPCM-stereo">
        <output outputSettingsName="lpcm"
                defaultSelection="$app_DefaultSelectionString,-sel:all">
        </output>
        <output outputSettingsName="flac-best"
        </output>
    </trackSettings>
    <!-- Save multi-channel LPCM as FLAC -->
    <trackSettings input="LPCM-multi">
        <output outputSettingsName="wavex"
        </output>
        </output>
    </trackSettings>
    <!-- Save TRUEHD as FLAC -->
    <trackSettings input="TRUEHD-stereo">
        </output>
        </output>
    </trackSettings>
    <trackSettings input="TRUEHD-multi">
        </output>
        </output>
    </trackSettings>
    <trackSettings input="MLP-stereo">
        </output>
        </output>
    </trackSettings>
    <trackSettings input="MLP-multi">
        </output>
        </output>
    </trackSettings>
    <!-- Save DTS-HDMA as FLAC -->
    <trackSettings input="DTSHDMA-stereo">
        </output>
        </output>
    </trackSettings>
    <trackSettings input="DTSHDMA-multi">
        </output>
        </output>
                audioMix="16B51">
        </output>
    </trackSettings>
    <!-- Save DTS-HD as FLAC -->
    <trackSettings input="DTSHD-stereo">
        </output>
        </output>
    </trackSettings>
    <trackSettings input="DTSHD-multi">
        </output>
        </output>
    </trackSettings>
    <!-- Save DTS-HD LBR (low quality) as FLAC (just to decode) -->
    <trackSettings input="DTSHDLBR-stereo">
        </output>
        </output>
        <output outputSettingsName="AC3-192"
        </output>
    </trackSettings>
    <trackSettings input="DTSHDLBR-multi">
        </output>
        </output>
        <output outputSettingsName="AC3-448"
        </output>
                audioMix="stereo16">
        </output>
    </trackSettings>
    <!-- Compress subtitles with ZLIB compression -->
    <trackSettings input="PGS">
        <output outputSettingsName="copyzlib"
        </output>
    </trackSettings>
    <trackSettings input="PGS-forced">
        </output>
    </trackSettings>
    <trackSettings input="VOBSUB">
        </output>
    </trackSettings>
    <trackSettings input="VOBSUB-forced">
        </output>
    </trackSettings>
    <trackSettings input="VOBSUBHD">
        </output>
    </trackSettings>
    <trackSettings input="VOBSUBHD-forced">
        </output>
    </trackSettings>
</profile>
mattias83
Post by mattias83 » Sat Jun 21, 2014 3:39 am
Great, thank you very much!
mattias83
Post by mattias83 » Sat Jun 21, 2014 4:02 am
Well for some reason it doesn't list the profile under the drop-down options for profiles. The file is named pcmflac.mmcp.xml and is in the main program folder. When I click profile I get the same standard list, with no option for the pcm-flac profile.
ndjamena
Post by ndjamena » Sat Jun 21, 2014 4:08 am
Did you get an error message when MakeMKV loaded?
-Edit- I'm using it right how to rip The Avengers. I added HRA to FLAC and am testing it out on an Italian track.
mattias83
Post by mattias83 » Sat Jun 21, 2014 4:10 am
mattias83 wrote:Well for some reason it doesn't list the profile under the drop-down options for profiles. The file is named pcmflac.mmcp.xml and is in the main program folder. When I click profile I get the same standard list, with no option for the pcm-flac profile.
Nope, no error message - it just won't give me the pcm-flac option.
ndjamena
Post by ndjamena » Sat Jun 21, 2014 4:13 am
You need to save it as utf-8, not ANSI. What OS are you using?
mattias83
Post by mattias83 » Sat Jun 21, 2014 4:15 am
ndjamena wrote:You need to save it as utf-8, not ANSI. What OS are you using?
Windows 7 32bit.
mattias83
Post by mattias83 » Sat Jun 21, 2014 4:20 am
Okay - saved a new file as utf-8 and now it shows up. Thanks again.
mattias83
Post by mattias83 » Sat Jun 21, 2014 4:41 am
Just tried it - worked perfectly. Thank you again.
ndjamena
Post by ndjamena » Tue Nov 11, 2014 10:14 pm
*cough*
I changed the profile to no longer "copy" PCM tracks and added a few things.
VideoJunkie888
Post by VideoJunkie888 » Thu Nov 27, 2014 2:36 pm
Thankyou so much ndjamena :D
the above .xml file works perfectly for me...
Many, thanks and much appreciation for your help!
