Japanese BD problems.
Chizumatic
I have a Japanese anime BD. It's got two audio tracks. One is the real one, and the other has commentary by a couple of the voice actors. When I ripped it using MakeMKV Beta 1.4.12, MakeMKV only showed one audio track. When I played the resulting MKV file, it turned out to be the commentary track, which isn't what I wanted.
Here's what MediaInfo says about that M2TS file:
General
Complete name : E:\BDMV\STREAM\00002.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 7.93 GiB
Duration : 26mn 52s
Overall bit rate : 42.2 Mbps
Maximum Overall bit rate : 48.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Duration : 26mn 52s
Bit rate : 37.5 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.754
Stream size : 7.04 GiB (89%)
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio #1
Menu ID : 1 (0x1)
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Signed
Muxing mode : Blu-ray
Duration : 26mn 52s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 295 MiB (4%)
Audio #2
Menu ID : 1 (0x1)
Format : PCM
Duration : 26mn 52s
This is what it said about the resulting MKV file:
General
Complete name : F:\Video\AIKA_ZERO_1\title00.mkv
Format : Matroska
File size : 6.93 GiB
Duration : 26mn 52s
Overall bit rate : 36.9 Mbps
Encoded date : UTC 2010-02-12 03:49:22
Writing application : MakeMKV v1.4.12 beta win(x64-release)
Writing library : libmakemkv v1.4.12 beta (0.7.7/0.8.1) win(x64-release)
Video
Format : AVC
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 26mn 50s
Resolution : 8 bits
Colorimetry : 4:2:0
Audio
Format : PCM
Codec ID : A_PCM/INT/LIT
Duration : 26mn 52s
Title : 2/0
Language : Japanese
Menu
00:00:00.000 : en:Chapter 00
00:02:37.240 : en:Chapter 01
00:04:07.247 : en:Chapter 02
00:11:55.214 : en:Chapter 03
00:24:09.948 : en:Chapter 04
00:25:40.539 : en:Chapter 05
00:26:45.103 : en:Chapter 06
General
Format : BDAV
Duration : 26mn 52s
Video
Menu ID : 1 (0x1)
Format : AVC
Duration : 26mn 52s
Resolution : 8 bits
Colorimetry : 4:2:0
Audio #1
Menu ID : 1 (0x1)
Format : PCM
Duration : 26mn 52s
Audio #2
Menu ID : 1 (0x1)
Format : PCM
Duration : 26mn 52s
General
Format : Matroska
Duration : 26mn 52s
Video
Format : AVC
Duration : 26mn 50s
Resolution : 8 bits
Colorimetry : 4:2:0
Audio
Format : PCM
Duration : 26mn 52s
Title : 2/0
Language : Japanese
Menu
- Contact:
Re: Japanese BD problems.
Please enable "log debug messages" in preferences, restart the program, create MKV again and post produced log file here.
Chizumatic
Debug log started at Tue Feb 16 03:28:42 2010 , written by MakeMKV v1.4.12 beta win(x64-release)
001005:0000 MakeMKV v1.4.12 beta win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Steven/MakeMKV_log.txt
005050:0000 Evaluation version, 26 day(s) out of 30 remaining
DISCID=2C8B5804C7D462A4F397372F0C37D9A15B3E1501
001002:0020 LIBMKV_TRACE: No CC5 in 00005
003307:0000 File 00002.mpls was added as title #0
003307:0000 File 00004.mpls was added as title #1
001002:0020 LIBMKV_TRACE: No CC5 in 00001
001002:0020 LIBMKV_TRACE: No CC5 in 00000
003307:0000 File 00003.mpls was added as title #2
003025:0000 Title #00011.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00010.m2ts was added as title #3
003307:0000 File 00009.m2ts was added as title #4
003307:0000 File 00013.m2ts was added as title #5
003025:0000 Title #00012.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005011:0000 Operation sucessfully completed
005014:0000 Saving 1 titles into directory F:/Video/AIKA_ZERO_1
005005:0000 1 titles saved
005036:0104 Copy complete. 1 titles saved.
Application exited at Tue Feb 16 03:42:15 2010
- Contact:
Thank you. I would ask you to send all *.mpls and *.clpi files from this disc to support@makemkv.com . Please compress them with archiver of your choice.
Chizumatic
Done. (It's a 58K zip file.)
Chizumatic
By the way, I had AnyDVD-HD enabled when I grabbed all those files. Is that a problem?
- Contact:
It souldn't be but it might. I'd appreciate if you can try again without anydvd just to be sure.Chizumatic wrote:By the way, I had AnyDVD-HD enabled when I grabbed all those files. Is that a problem?
- Contact:
Error confirmed and will be corrected in a next version. Unfortunately there is no workaround with current version.
