No Chapters on "Four Lions"
cyborg
#1 Post by cyborg » Thu Jun 19, 2014 4:54 pm
When trying to rip the Blu-Ray "Four Lions", I noticed that MakeMKV does not detect the chapters correctly.
MakeMKV detects the main movie file, with a size of 26.4GB, source file name is 00014.m2ts. But it does not contain chapters.
When opening the disc with MPC-HC, the file 01008.mpls is opened and the chapters are detected correctly.
Is there anything I can do in MakeMKV to detect the chapters properly? I did not have that problem yet on approx. 50 rips I have done so far.
Re: No Chapters on "Four Lions"
#2 Post by Woodstock » Thu Jun 19, 2014 9:16 pm
Debug log from the rip would be nice.... FAQ link in my signature tells you how to turn it on.
Are you backing the disk up, or ripping to MKV files?
cyborg
#3 Post by cyborg » Fri Jun 20, 2014 5:58 am
Debug log started at Fri Jun 20 05:49:56 2014 , written by MakeMKV v1.8.11 win(x64-release)
001005:0000 MakeMKV v1.8.11 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\cyborg/MakeMKV_log.txt
003305:0000 AACS directory not present, assuming unencrypted disc
003025:0000 Title #01000.mpls has length of 222 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #01001.mpls has length of 6 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
001003:0020 DEBUG: Code 0 at MNr)P~[kLhG8s+Qyp:213130145
001003:0020 DEBUG: Code 5 at MNr)P~[kLhG8s+Qyp:29394114
003025:0000 Title #00000.m2ts has length of 1 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 1 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 1 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 1 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 1 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 6 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 6 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 6 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 151 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 128 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 70 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 88 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 111 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 111 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003307:0000 File 00014.m2ts was added as title #0
003025:0000 Title #00015.m2ts has length of 842 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 167 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 187 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 241 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 143 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 117 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 133 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 124 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00023.m2ts has length of 788 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00024.m2ts has length of 240 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00025.m2ts has length of 506 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00026.m2ts has length of 390 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00027.m2ts has length of 732 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00028.m2ts has length of 126 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
003025:0000 Title #00029.m2ts has length of 126 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Application exited at Fri Jun 20 05:50:03 2014
I am ripping to MKV files. I am ripping from an ISO file which was created before. I will try to rip to MKV from the original disk later.
#4 Post by mike admin » Sun Jun 22, 2014 10:34 am
Please send all CLPI and MPLS files per instructions at /faq/item/8
cyborg
#5 Post by cyborg » Sun Jun 22, 2014 2:57 pm
I've sent all CLPI/MPLS files, log file and description to the support-email-address.
