Greetings,
I was able to rip season 7 just fine, but season 8 has been problematic. The log for disc 1 follows. Using a Macbook Pro 13" with Mavericks, external LaCie BD drive.
MakeMKV v1.8.11 darwin(x86-release) started
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-898 HC10d" opened in OS access mode.
Optical drive "BD-RE TSSTcorp BDDVDW SN-506BB SB00d" opened in OS access mode.
Loaded 50 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
BD+ code processed, got 1 FUT(s) for 8 clip(s)
File 00800.mpls was added as title #0
File 00801.mpls was added as title #1
File 00802.mpls was added as title #2
File 00804.mpls was added as title #3
Title #00001.mpls has length of 75 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00856.mpls was added as title #4
File 00807.mpls was added as title #5
Title 00850.mpls is equal to title 00800.mpls and was skipped
Title 00851.mpls is equal to title 00801.mpls and was skipped
Title 00852.mpls is equal to title 00802.mpls and was skipped
File 00853.mpls was added as title #6
Title 00854.mpls is equal to title 00804.mpls and was skipped
File 00855.mpls was added as title #7
Title 00806.mpls is equal to title 00856.mpls and was skipped
Title 00857.mpls is equal to title 00807.mpls and was skipped
File 00456.mpls was added as title #8
Title 00803.mpls is equal to title 00853.mpls and was skipped
Title 00805.mpls is equal to title 00855.mpls and was skipped
File 00479.mpls was added as title #9
Title #00459.mpls has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00458.mpls was added as title #10
Title #00061.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00465.m2ts was added as title #11
Title #00466.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00467.m2ts has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00468.m2ts has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00463.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00471.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00472.m2ts was added as title #12
File 00473.m2ts was added as title #13
File 00474.m2ts was added as title #14
File 00475.m2ts was added as title #15
File 00476.m2ts was added as title #16
Title #00459.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00449.m2ts has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00448.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00447.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00446.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00470.m2ts was added as title #17
File 00462.m2ts was added as title #18
Title #00461.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00460.m2ts was added as title #19
Saving 10 titles into directory /Volumes/StorEDGE/MakeMKV Output
Forced subtitles track #3 turned out to be empty and was removed from output file
Forced subtitles track #5 turned out to be empty and was removed from output file
Forced subtitles track #7 turned out to be empty and was removed from output file
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00801.m2ts' at offset '5170003968'
Failed to save title 1 to file /Volumes/StorEDGE/MakeMKV Output/24,_Season_8_Disc_1_t01.mkv
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '0'
Failed to save title 2 to file /Volumes/StorEDGE/MakeMKV Output/24,_Season_8_Disc_1_t02.mkv
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '0'
Failed to save title 3 to file /Volumes/StorEDGE/MakeMKV Output/24,_Season_8_Disc_1_t03.mkv
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00463.m2ts' at offset '0'
Failed to save title 4 to file /Volumes/StorEDGE/MakeMKV Output/24,_Season_8_Disc_1_t04.mkv
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00468.m2ts' at offset '0'
Failed to save title 5 to file /Volumes/StorEDGE/MakeMKV Output/24,_Season_8_Disc_1_t05.mkv
Failed to save title 6 to file /Volumes/StorEDGE/MakeMKV Output/24,_Season_8_Disc_1_t06.mkv
Failed to save title 7 to file /Volumes/StorEDGE/MakeMKV Output/24,_Season_8_Disc_1_t07.mkv
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00465.m2ts' at offset '0'
Failed to save title 11 to file /Volumes/StorEDGE/MakeMKV Output/24,_Season_8_Disc_1_t11.mkv
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00460.m2ts' at offset '0'
Failed to save title 19 to file /Volumes/StorEDGE/MakeMKV Output/24,_Season_8_Disc_1_t19.mkv
1 titles saved, 9 failed
24, Season 8 BD
Re: 24, Season 8 BD
This is an error message that is characteristic of using a USB-powered optical drive with insufficient power on the USB port to spin it at full speed. Often, these drives will operate adequately at slower speeds, but, once they get past about 4x, they disconnect from the computer.Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '0'
Make sure the drive is plugged into a port that has full power available, or use a powered hub. Many of these drives come with special cables that allow them to be plugged into two USB ports to get sufficient power to operate, but they must both be powered.
