cameleon078
Post
by cameleon078 » Tue Jun 17, 2014 8:35 pm
I have some issues to make mkv with DVD of The Wolf of Wall Street.
Two errors are printed :
Saving 1 titles into directory /home/samuel/Vid?os/MakeMkv/_LE_LOUP_DE_WALL_STREET_7D30
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/VIDEO_TS/VTS_22_1.VOB' at offset '3242469376'
Failed to save title 5 to file /home/samuel/Vid?os/MakeMkv/_LE_LOUP_DE_WALL_STREET_7D30/title05.mkv
0 titles saved, 1 failed
Regards.
Post
by Woodstock » Tue Jun 17, 2014 10:53 pm
Enable debug logging (see FAQ link in signature) and post the log information in a reply.
It appears to be a hardware problem with the drive, however. Debug logging may give more information on the issue, though.
smutel
Post
by smutel » Thu Jun 19, 2014 7:03 pm
Debug log started at Thu Jun 19 18:42:36 2014 , written by MakeMKV v1.8.11 linux(x64-release)
001005:0000 MakeMKV v1.8.11 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/samuel/MakeMKV_log.txt
003028:0000 Title #1 was added (1 cell(s), 0:02:26)
003028:0000 Title #2 was added (1 cell(s), 0:02:26)
Title skip vts=2 pgcn=1 hash=1177182DDDB02EE7
003025:0000 Title #4 has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #5 was added (1 cell(s), 0:02:15)
003025:0000 Title #6 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #7 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=8 pgcn=1 hash=C35986A964777E52
Title skip vts=9 pgcn=2 hash=C8940D5EEC65B11B
Title skip vts=9 pgcn=3 hash=D7A2CD7514F3B890
Title skip vts=9 pgcn=4 hash=7A685F1B039AB73A
Title skip vts=9 pgcn=5 hash=94561DDC848993C2
Title skip vts=9 pgcn=6 hash=93720245D3574BC4
Title skip vts=9 pgcn=7 hash=202D4CA56B515AAB
Title skip vts=9 pgcn=8 hash=B9A8C0CCEBB1F5BF
Title skip vts=9 pgcn=9 hash=88902DE39AEE6D8A
Title skip vts=9 pgcn=10 hash=8E2518CEBA8DBE93
003025:0000 Title #10/10 has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=9 pgcn=12 hash=FC875822A8174F3E
Title skip vts=9 pgcn=13 hash=552B50BADAE45D6A
Title skip vts=9 pgcn=14 hash=4FBD1A59796535F3
Title skip vts=9 pgcn=15 hash=2D6D19FD2B17AABA
Title skip vts=9 pgcn=16 hash=36C7E552428F1A60
Title skip vts=9 pgcn=17 hash=C518337F2D6471E4
Title skip vts=9 pgcn=18 hash=2FFBB96D0198FEC5
Title skip vts=9 pgcn=19 hash=AD5DD110093E00FE
Title skip vts=9 pgcn=20 hash=EA7ED3E166F48DC6
Title skip vts=9 pgcn=21 hash=AE07FF59633FC197
Title skip vts=9 pgcn=22 hash=01BA1173F1DA9D2A
Title skip vts=9 pgcn=23 hash=501C314222305BA9
Title skip vts=9 pgcn=24 hash=F4367C03C92BB46B
Title skip vts=9 pgcn=25 hash=35DCA69D8D319341
003028:0000 Title #11 was added (24 cell(s), 2:22:03)
003028:0000 Title #12 was added (29 cell(s), 2:52:12)
Title skip vts=12 pgcn=1 hash=33DA91BF5536274A
003028:0000 Title #14 was added (29 cell(s), 2:52:12)
003028:0000 Title #15 was added (29 cell(s), 2:52:12)
003028:0000 Title #16 was added (29 cell(s), 2:52:12)
003028:0000 Title #17 was added (26 cell(s), 2:37:17)
Title skip vts=17 pgcn=1 hash=516F04332FC3E9C9
003028:0000 Title #19 was added (29 cell(s), 2:52:12)
003028:0000 Title #20 was added (25 cell(s), 2:29:55)
Title skip vts=20 pgcn=1 hash=0DDF375F4C7D68AF
003028:0000 Title #22 was added (29 cell(s), 2:52:12)
003028:0000 Title #23 was added (31 cell(s), 2:53:17)
003028:0000 Title #24 was added (29 cell(s), 2:52:12)
Title skip vts=24 pgcn=1 hash=D1C56E21112B57F2
003028:0000 Title #26 was added (31 cell(s), 2:53:17)
003027:0000 Title 2 in VTS 1 is equal to title 1 and was skipped
003027:0000 Title 1 in VTS 11 is equal to title 1 and was skipped
003027:0000 Title 2 in VTS 22 is equal to title 1 and was skipped
003027:0000 Title 1 in VTS 23 is equal to title 1 and was skipped
005014:0000 Saving 1 titles into directory /home/samuel/Vid?os/MakeMkv/_LE_LOUP_DE_WALL_STREET_7D30
004007:0010 AV synchronization issues were found in file '/home/samuel/Vid?os/MakeMkv/_LE_LOUP_DE_WALL_STREET_7D30/title05.mkv' (title #6)
004008:0010 AV sync issue in stream 1 at 2:52:24.480 with duration of 1247.178ms : audio gap - 38.974 missing frame(s)
004047:0010 AV sync issue in stream 0 at 2:52:25 : video frame timecode differs by -79.366ms
004008:0010 AV sync issue in stream 2 at 2:52:24.544 with duration of 1183.178ms : audio gap - 36.974 missing frame(s)
004008:0010 AV sync issue in stream 2 at 2:52:30.024 with duration of 160ms : audio gap - 5 missing frame(s)
004008:0010 AV sync issue in stream 2 at 2:52:30.504 with duration of 160ms : audio gap - 5 missing frame(s)
001003:0020 DEBUG: Code 1073741829 at df5;HQYD(q"4#eq.:29393953
001003:0020 DEBUG: Code 2 at <[AFVZJdmx\{1cIW:213137827
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_22_1.VOB' at offset '3242469376'
001003:0020 DEBUG: Code 0 at eH($%B2_#w?{L<GW]Sq::121263038
001003:0020 DEBUG: Code 0 at }FZTQmw#3mNk5#-9llf:121261750
001003:0020 DEBUG: Code 0 at eH($%B2_#w?{L<GW]Sq::213130559
001003:0020 DEBUG: Code 3680389 at eH($%B2_#w?{L<GW]Sq::29393286
001003:0020 DEBUG: Code 0 at =c>#8%@-Dp}#}vygR-H3B:213135090
004008:0010 AV sync issue in stream 1 at 2:52:29.960 with duration of 224ms : audio gap - 7 missing frame(s)
004008:0010 AV sync issue in stream 1 at 2:52:30.440 with duration of 224ms : audio gap - 7 missing frame(s)
004008:0010 AV sync issue in stream 1 at 2:52:30.920 with duration of 224ms : audio gap - 7 missing frame(s)
004008:0010 AV sync issue in stream 1 at 2:52:31.400 with duration of 224ms : audio gap - 7 missing frame(s)
004008:0010 AV sync issue in stream 1 at 2:52:31.880 with duration of 224ms : audio gap - 7 missing frame(s)
004008:0010 AV sync issue in stream 1 at 2:52:32.360 with duration of 224ms : audio gap - 7 missing frame(s)
004008:0010 AV sync issue in stream 2 at 2:52:30.984 with duration of 160ms : audio gap - 5 missing frame(s)
004008:0010 AV sync issue in stream 2 at 2:52:31.464 with duration of 160ms : audio gap - 5 missing frame(s)
004008:0010 AV sync issue in stream 2 at 2:52:31.944 with duration of 160ms : audio gap - 5 missing frame(s)
004008:0010 AV sync issue in stream 2 at 2:52:32.424 with duration of 160ms : audio gap - 5 missing frame(s)
004008:0010 AV sync issue in stream 2 at 2:52:32.904 with duration of 160ms : audio gap - 5 missing frame(s)
004008:0010 AV sync issue in stream 2 at 2:52:33.384 with duration of 160ms : audio gap - 5 missing frame(s)
004008:0010 AV sync issue in stream 2 at 2:52:33.864 with duration of 160ms : audio gap - 5 missing frame(s)
004008:0010 AV sync issue in stream 2 at 2:52:34.344 with duration of 160ms : audio gap - 5 missing frame(s)
004008:0010 AV sync issue in stream 1 at 2:52:32.840 with duration of 224ms : audio gap - 7 missing frame(s)
004008:0010 AV sync issue in stream 1 at 2:52:33.320 with duration of 224ms : audio gap - 7 missing frame(s)
004008:0010 AV sync issue in stream 1 at 2:52:33.800 with duration of 224ms : audio gap - 7 missing frame(s)
004008:0010 AV sync issue in stream 1 at 2:52:34.280 with duration of 224ms : audio gap - 7 missing frame(s)
004008:0010 AV sync issue in stream 1 at 2:52:34.760 with duration of 224ms : audio gap - 7 missing frame(s)
004008:0010 AV sync issue in stream 1 at 2:52:35.240 with duration of 224ms : audio gap - 7 missing frame(s)
004008:0010 AV sync issue in stream 2 at 2:52:34.824 with duration of 160ms : audio gap - 5 missing frame(s)
004008:0010 AV sync issue in stream 2 at 2:52:35.304 with duration of 160ms : audio gap - 5 missing frame(s)
004008:0010 AV sync issue in stream 2 at 2:52:35.784 with duration of 160ms : audio gap - 5 missing frame(s)
004008:0010 AV sync issue in stream 2 at 2:52:36.264 with duration of 160ms : audio gap - 5 missing frame(s)
004008:0010 AV sync issue in stream 2 at 2:52:36.744 with duration of 160ms : audio gap - 5 missing frame(s)
005003:0000 Failed to save title 5 to file /home/samuel/Vid?os/MakeMkv/_LE_LOUP_DE_WALL_STREET_7D30/title05.mkv
005004:0080 0 titles saved, 1 failed
smutel
Post
by smutel » Thu Jun 19, 2014 7:55 pm
The error appear when I want to extrat this one:
Title information
Source title ID: 23
Duration: 2:53:17
Chapters count: 31
Segment count: 1
Segment map: 1-31
File name: title05.mkv
No error appear when I want to extract this one:
Title information
Source title ID: 24
Duration: 2:52:12
Chapters count: 29
Segment count: 1
Segment map: 1-29
File name: title06.mkv
