Star Trek Enterprise s01d03
neex02
Post by neex02 »
I'm getting the following messages:
MakeMKV v1.8.11 darwin(x86-release) started
Optical drive "BD-ROM Optiarc BD ROM BC-5550H B881" opened in DASPI v1.4 mode.
Backing up disc into folder "/Users/nch/Desktop"
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '2236416000'
Backup failed
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '2247487488'
Backup failed
I also tried 1.8.9 and got the same error.
I am running OSX 10.9.3 on a Mac Mini with a USB Blu-Ray. Haven't had issues with any disc up to this point. Thanks!
Re: Star Trek Enterprise s01d03
Make sure the drive has plenty of power. A lot of USB drives "fail" when you spin them up, because they hit the current limit of their USB power supply.
They're fine for playing, but anything that takes them to their maximum speed will cause the drive to disconnect momentarily.
neex02
Post by neex02 »
Well I'm 99% sure that I've got enough power to the drive, since I just tried it with the power adapter attached.
Nonetheless, I'm still getting the following error:
Backing up disc into folder "/Volumes/Movies-A HD/backup/STE_S1_D3"
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '2221731840'
Backup failed
What else could be the issue? Bad disc? (Doesn't appear to be scratched and plays just fine.) Like I said, I haven't had any issue with any other discs, even other from this series. Thanks.
EDIT: Just reproduced the error again and generated this log:
Debug log started at Fri Jun 20 02:12:54 2014 , written by MakeMKV v1.8.11 darwin(x86-release)
001005:0000 MakeMKV v1.8.11 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/nch/MakeMKV_log.txt
002014:0000 Optical drive "BD-ROM Optiarc BD ROM BC-5550H B881" opened in DASPI v1.4 mode.
005072:0000 Backing up disc into folder "/Volumes/Movies-A HD/backup/STE_S1_D3"
DAFD=PAAAADAAAAEABDQkEGwEEAQ==
DCE=mzi+lERJMt18YErRZZsbmtXHk7H61IQV14u/xLVChpHnBfiAfqtIVpS46er/21HMp9VEu/mt2TvlDXLOM/lty6BUMre7KFs5Om8UZ/8efLIKRIOVC0kBvWerMqltP/maQW90Qxxw+IaRmXdCeTfgkOZwX64QDZOaeg==
DCE=cFs1lObiVABfJe5s4fQO3Jr9bZcaqnpoD8NMZN5URCttKrtQ75dwznhvbhryrPL7Tzsp1beywEiqi6Ten0Wy4JXQB6HUzy7tj0bbKkXvOfmq7f3/9RP2xmCcQqmSaoLQ7WdxK5qVjXriXD+dwl9XSRCGVD3tnpvrFg==
001003:0020 DEBUG: Code 1073741829 at &:ScxH-S}++RkDH[:29393953
001003:0020 DEBUG: Code 2 at UK>27R`LGO6tpM5Z:213137827
002003:0000 Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '2220748800'
001003:0020 DEBUG: Code 0 at 6mMpP{QDf\5Xl<FmK'Y:121265890
001003:0020 DEBUG: Code 0 at L\CUw+T:BI'$~'YO?F),:121265108
005069:0080 Backup failed
005080:0204 Backup failed.
Application exited at Fri Jun 20 02:28:17 2014
And here are the CLPI and MPLS files.
neex02
Post by neex02 »
Well I've since tried to make a disc image of the disc using the Disk Utility, mainly to test to see if it had the same SCSI error. It did. In fact, it killed my Blu-Ray drive attempting to read the disc. At some point the drive started making an excessive amount of loud noises. I let it go for a couple of minutes or so, thinking, well its doing what its supposed to do and it won't break itself-- anyway, Disc Utility eventually gave a similar error that Make MKV did, unmounted the disc, and ejected it.
Now, my drive tray will not stay closed. If I try to close it, it just pops back open after about 30 seconds, regardless of whether there is a disc in there or not. I've tried it with several computers.
