anyone experiencing the same annoying issue: when MakeMKM is doing a BluRay conversion the Screen Saver doesn't kick in... so my display is always on until the conversion process is complete... When it's done, then the Screensave will work.
thx
J.
mac os x screen saver not kicking in while converting
johnnygoodface
Re: mac os x screen saver not kicking in while converting
This is unfortunately by design. MakeMKV prevents your mac going to sleep mode during conversion. To my best knowledge there is no API to prevent sleep, but still allow screensaver to run.
Romansh
In theory it should be possible:
kIOPMAssertionTypeNoIdleSleep wrote:kIOPMAssertionTypeNoDisplaySleep
Use as AssertionType argument to IOPMAssertionCreate. The idle display will not sleep when enabled, and consequently the system will not idle sleep.
When asserted and set to level kIOPMAssertionLevelOn, the system will prefer to enter the Dark Wake state, or remain in Dark Wake if already there, rather than go to sleep.
Pass as the AssertionType argument to IOPMAssertionCreate. The system will not idle sleep when enabled (display may sleep). Note that the system may sleep for other reasons.
Thanks, MakeMKV is still using 10.5-compatible API and the power assertions got introduced in 10.6 . I was unaware of them. Will be fixed in the next version.
johnnygoodface
Any progress on this?
Thx
Jean
Thx
Jean
