The Butler - Scsi error
cameleon078
Post by cameleon078 » Tue Jun 17, 2014 8:53 pm
I want to make mkv with DVD The Butler.
I have the error messages below:
Error 'Scsi error - ILLEGAL REQUEST:COMMAND SEQUENCE ERROR' occurred while issuing SCSI command A40..010C1 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COMMAND SEQUENCE ERROR' occurred while issuing SCSI command A40..00CC2 to device 'SG:dev_11:0'
Thanks in advance.
Regards.
Re: The Butler - Scsi error
Post by Woodstock » Tue Jun 17, 2014 10:54 pm
Combined with the error you posted elsewhere, it would appear you have a hardware problem.
smutel
Post by smutel » Thu Jun 19, 2014 8:11 pm
For this one I think that the DVD is defective.
003028:0000 Title #1 was added (1 cell(s), 0:02:25)
003025:0000 Title #2 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #3 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #4 was added (1 cell(s), 0:21:10)
003028:0000 Title #5 was added (1 cell(s), 0:03:42)
003028:0000 Title #6 was added (9 cell(s), 0:20:02)
003025:0000 Title #7 has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #8 was added (1 cell(s), 0:06:36)
003025:0000 Title #9 has length of 89 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #10 has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #11 was added (1 cell(s), 0:03:45)
003025:0000 Title #12 has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #13 has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #14 has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #15 has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #16 was added (1 cell(s), 0:05:56)
003025:0000 Title #17 has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #18 was added (1 cell(s), 0:04:59)
003028:0000 Title #19 was added (1 cell(s), 0:02:19)
003028:0000 Title #20 was added (1 cell(s), 0:02:25)
003025:0000 Title #21 has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #22 was added (21 cell(s), 2:06:53)
005014:0000 Saving 1 titles into directory /home/samuel/Vid?os/MakeMkv/LE_MAJORDOME
001003:0020 DEBUG: Code 1073741829 at df5;HQYD(q"4#eq.:29393953
001003:0020 DEBUG: Code 2 at <[AFVZJdmx\{1cIW:213137827
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_13_1.VOB' at offset '764571648'
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading '/VIDEO_TS/VTS_13_1.VOB' at offset '764571648'
001003:0020 DEBUG: Code 0 at eH($%B2_#w?{L<GW]Sq::121263038
001003:0020 DEBUG: Code 0 at }FZTQmw#3mNk5#-9llf:121261750
001003:0020 DEBUG: Code 0 at eH($%B2_#w?{L<GW]Sq::213130559
001003:0020 DEBUG: Code 2470478 at eH($%B2_#w?{L<GW]Sq::29393286
001003:0020 DEBUG: Code 0 at =c>#8%@-Dp}#}vygR-H3B:213135090
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
005003:0000 Failed to save title 10 to file /home/samuel/Vid?os/MakeMkv/LE_MAJORDOME/title10.mkv
005004:0080 0 titles saved, 1 failed
