makemkv 1.8.10 segfaults
trompette
Post by trompette » Wed Jun 11, 2014 11:00 am
Hi, running
makemkvcon info disc:/dev/sr0
fails on Gentoo Linux. I have ffmpeg 2.2 and glibc 2.19
Strace : http://sprunge.us/PHPX
GDB :
(gdb) r info disc:/dev/sr0
Starting program: /home/user/.local/bin/makemkvcon info disc:/dev/sr0
warning: Could not load shared library symbols for linux-vdso.so.1.
Do you need "set solib-search-path" or "set sysroot"?
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
[New Thread 0x7fffd3b9b700 (LWP 29400)]
MakeMKV v1.8.10 linux(x64-release) started
[New Thread 0x7fffd32b6700 (LWP 29401)]
[New Thread 0x7fffd2ab5700 (LWP 29402)]
[New Thread 0x7fffd22b4700 (LWP 29406)]
Program received signal SIGSEGV, Segmentation fault.
0x00007fffd339b000 in ?? ()
(gdb) bt
#0  0x00007fffd339b000 in ?? ()
#1  0x000000000055858d in ?? ()
#2  0x000000000044c8b4 in ?? ()
#3  0x000000000044ca1a in ?? ()
#4  0x000000000044cb3a in ?? ()
#5  0x000000000044603b in ?? ()
#6  0x000000000042784b in ?? ()
#7  0x0000000000418bc1 in ?? ()
#8  0x0000000000418e1d in ?? ()
#9  0x0000000000406c34 in ?? ()
#10 0x00007ffff73afa45 in __libc_start_main () from /lib64/libc.so.6
#11 0x00000000004072b1 in ?? ()
#12 0x00007fffffffe1a8 in ?? ()
#13 0x000000000000001c in ?? ()
#14 0x0000000000000003 in ?? ()
#15 0x00007fffffffe4f5 in ?? ()
#16 0x00007fffffffe514 in ?? ()
#17 0x00007fffffffe519 in ?? ()
#18 0x0000000000000000 in ?? ()
(gdb)
Re: makemkv 1.8.10 segfaults
Post by mike admin » Tue Jun 17, 2014 8:29 pm
Please try 1.8.11 and see if it still segfaults. If yes, then please PM the core from 1.8.11 .
macenzy
Post by macenzy » Fri Jun 20, 2014 2:05 pm
Seems I have the same issue. Just sent a PM to mike with a core dump. Hope this helps.
trompette
Post by trompette » Fri Jun 20, 2014 3:27 pm
Same thing for me, I PM'ed you the core.
