I'm trying to rip my own copy of Star Trek Next Generation, Season 1, Disc 1. Two titles that share the same segment failed to ripped. I suspect that shared segment is either the opening or credit.
Saving 2 titles into directory D:/ using profile 'FLAC' from file 'C:\Program Files (x86)\MakeMKV/flac.mmcp.xml'
AV synchronization issues were found in file 'D://title01.mkv' (title #2)
AV sync issue in stream 1 at 0:00:00 with duration of 792.455ms : audio gap was filled with silence
DEBUG: Code 0 at O_h|[Z2T<;A(7V><K1g:213132744
DEBUG: Code 0 at O_h|[Z2T<;A(7V><K1g:213137367
DEBUG: Code 0 at O_h|[Z2T<;A(7V><K1g:213135021
DEBUG: Code 0 at A/9!yS5V6wwwyK2O&Z `:29395057
DEBUG: Code 0 at 4(yOYXRk(~=y3s-rF"jD,:213135090
DEBUG: Code 20 at pb2S`[J>e5XrCCC{:29395379
DEBUG: Code 0 at pb2S`[J>e5XrCCC{:213133227
DEBUG: Code 0 at bd\[Kd6uTi,QKe730o}M:29393286
Failed to save title 1 to file D://title01.mkv
Failed to save title 2 to file D://title02.mkv
0 titles saved, 2 failed
If that is not possible, how about keeping the mkv file rather than deleting them right after an error was encountered? That way I can re-encode to trim off problematic section.
