Startrek Enterprise S2 Disk 5 Title 01
freman
#1 Post by freman » Thu Jun 05, 2014 3:45 pm
Greetings
So I managed to rip the first season just fine, and most of the second season, but I can't rip title 01 from disk 5 of season 2 - it seems to go all the way through but at the end it just says it failed.
MakeMKV v1.8.10 win(x64-release) started
Debug logging enabled, log will be saved as MakeMKV_log.txt
Evaluation version, 26 day(s) out of 30 remaining
File 00010.mpls was added as title #0
Title #00013.mpls has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.mpls has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00004.mpls was added as title #1
File 00003.mpls was added as title #2
File 00002.mpls was added as title #3
File 00001.mpls was added as title #4
Title #00073.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00066.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00063.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00064.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00009.m2ts was added as title #5
Title #00016.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00065.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00093.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00054.m2ts was added as title #6
Title #00040.m2ts has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00069.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 233 at 6CNeR6ZbMgzLPkA9I/vIDE54:0
Saving 1 titles into directory D:/Make MKV/Star_Trek_Enterprise_Season_2_Disc_5
DEBUG: Code 0 at O_h|[Z2T<;A(7V><K1g:213132744
DEBUG: Code 0 at O_h|[Z2T<;A(7V><K1g:213137367
DEBUG: Code 0 at O_h|[Z2T<;A(7V><K1g:213135021
DEBUG: Code 0 at 4(yOYXRk(~=y3s-rF"jD,:213135090
DEBUG: Code 0 at Q.'fmXp (O|q=Ba-::213131893
DEBUG: Code 0 at Q.'fmXp (O|q=Ba-::121263406
DEBUG: Code 0 at Q.'fmXp (O|q=Ba-::29393907
Failed to save title 1 to file D:/Make MKV/Star_Trek_Enterprise_Season_2_Disc_5/Star_Trek_Enterprise_Season_2_Disc_5_t01.mkv
0 titles saved, 1 failed
Any help?
Is it perhaps the tiny scratch on the disc? (I haven't tried it in a bluray player yet)
Edit: Just ran the episode through on my bluray player, works fine...
Re: Startrek Enterprise S2 Disk 5 Title 01
#2 Post by Woodstock » Thu Jun 05, 2014 5:35 pm
Try it with version 1.8.9 instead. /download/old/
freman
#3 Post by freman » Sun Jun 08, 2014 10:29 am
1.8.9 refuses to run, says it's too old.
edit, nvm I found the beta key and now feel like an idiot
second edit: works like a charm!
third edit: thanks, by the way.
