Elysium 7.1 DTS-HD MA > FLAC crashes MakeMKV 1.8.10
The Masked Onion
Post by The Masked Onion »
I'm trying to rip the BR of Elysium and converting the 7.1 DTS-HD MA to FLAC. when I click the MakeMKV button the GUI freezes up and goes in to a not responding state and then a "Fatal error occurred, program will now exit window" appears.
If I select the DTS-Core and not the DTS-HD MA MakeMKV successfully copies the title.
I'm pretty sure the problem is with the 7.1 DTS-HD MA being 16bit.
Track information
Type: Audio
Name: Surround 7.1 (English)
Language: English
Codec: DTS-HD Master Audio ? FLAC
Channels: 8
Channel layout: 7.1
Sample rate: 48000
Bits per sample: 16
Output format: FLAC audio ( Lossless conversion )
Output description: Save as FLAC (fast compression)
MKV Flags: Default
I have tried making a TESTDUMP but MakeMKV will crash before any data is written.
Re: Elysium 7.1 DTS-HD MA > FLAC crashes MakeMKV 1.8.10
Post by mike admin »
The Masked Onion wrote:I'm pretty sure the problem is with the 7.1 DTS-HD MA being 16bit.
Yes, this is a confirmed bug in mmdtsdec. It will be fixed in the next version, and you would need to use dtsdecoderdll.dll at least version 1.0.0.5 (from year 2009, so you're likely to have more recent version already) to decode such streams.
What troubles me, is a crash during testdump. Do you by any chance have a full debug log from failed testdump attempt?
The Masked Onion
I hope this is suitable because I'm using the movie that i ripped with Makemkv in backup mode for the logs below.
MakeMKV log
http://pastebin.com/hXg5uPcf
Link to CLIPINF and MPLS files
https://www.mediafire.com/folder/yhf114 ... keMKV_Dump
The Masked Onion
I have tried to rip Elysium with MakeMKV 1.8.11 and it still fails.
I have been able to create a TESTDUMP with version 1.8.11 but it still crashes at the end of procedure showing the same error in the first post.
I have emailed support@makemkv.com with the links to download the TESTDUMP.
