Bluray Region Coding
tripplesixty
Post by tripplesixty »
When using the backup to disk functionality within makemkv, does it strip the region codes? If I were to buy a bluray that was sold in another region would I be able to play this back locally with software the enforces region code checking?
electronicsguy
Re: Bluray Region Coding
Post by electronicsguy »
why not just rip it?
tripplesixty wrote:When using the backup to disk functionality within makemkv, does it strip the region codes? If I were to buy a bluray that was sold in another region would I be able to play this back locally with software the enforces region code checking?
Post by mike admin »
Region information is ignored by MakeMKV, and there is no way to put region information into MKV file anyway. So yes, if MKV file is playable by your software then that's all that matters.
