Can't seem to rip BluRays
ajiva
Post by ajiva » Sat May 31, 2014 12:59 pm
Lately whenever I rip one of my movies the process completes but when I open the MKV the output looks like it's still encrypted. I have the following config:
MacOS 10.9 (2012 IMac)
External BluRay (that has worked fine for almost a year)
MakeMKV 1.8.10
Here's what it looks like: http://imgur.com/awTPtZ5
Ideas?
Re: Can't seem to rip BluRays
Post by mike admin » Sun Jun 01, 2014 6:54 am
Do you get any errors or warnings during conversion? Please post the log file.
ajiva
Post by ajiva » Mon Jun 02, 2014 1:01 pm
Debug log started at Mon Jun  2 12:57:38 2014 , written by MakeMKV v1.8.10 darwin(x86-release)
001005:0000 MakeMKV v1.8.10 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as ~/MakeMKV_log.txt
002010:0000 Optical drive "BD-ROM HL-DT-ST BDDVDRW CT21N 1.00d" opened in OS access mode.
DAFD=PAAAADAAAAEABDQEEAQEEAQ==
DCE=pNy7CTRlAFapwUo4NULRKkMI0fK5MwLyudfC0H9oiYlRsvRoiXdP9WOEX11ENCETovdWIX4UDRfTj2zQWPgE8AYBO5Sn9XTdiYri40F9Qr1N6FgvDhispk8n9/GkuGrGxr7U3fl5xU1C4XjG1yvRdDEsQ6ZAJrH3aw==
DISCID=8336D834795CE25C07A060216FB7443D16EC0A96
003025:0000 Title #00053.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00054.mpls has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00055.mpls was added as title #0
003307:0000 File 00100.mpls was added as title #1
003025:0000 Title #00017.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00120.mpls has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00011.m2ts was added as title #2
003025:0000 Title #00013.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00032.m2ts was added as title #3
003025:0000 Title #00034.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00039.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00040.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00041.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00050.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00051.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00055.m2ts was added as title #4
003025:0000 Title #00057.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00058.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 4 titles into directory ~/Desktop/Gravity
005005:0080 4 titles saved
005036:0104 Copy complete. 4 titles saved.
Application exited at Mon Jun  2 12:59:22 2014
