Wolf Children US Release
YxmeN
Post by YxmeN »
Tried ripping on my drive, HL-DT-ST BD-RE WH10LS30.
The disc seems to play fine.
Here is the log:
Debug log started at Sat May 31 17:19:58 2014 , written by MakeMKV v1.8.10 win(x64-release)
001005:0000 MakeMKV v1.8.10 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Ry/MakeMKV_log.txt
005053:0308 This functionality is shareware. You may evaluate it for 30 days after what you would need to purchase an activation key if you like the functionality. Do you want to start evaluation period now?
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
DAFD=PAAAADAAAAEABDQUEAQEBAQ==
DCE=8eXMLoe3Kj/nXgzUDvw/6NmPJa3uH86BThwIKqZqPdAKTaLfAX6Lddoa3g0X3G0jZ7XwXGdrcSqJzxxegvd+Jkqirw7pBlpJ9GzgdSJ8Enp6YkqvmoyYMc/ihgcvqMEKk22XL8JJFOu+NvCA7t5RsguTi2uBWr/jnw==
DISCID=D8083D3180FAD26DAA0C44BA8E55E87469E902FD
003307:0000 File 00000.mpls was added as title #0
003307:0000 File 00001.mpls was added as title #1
003307:0000 File 00015.mpls was added as title #2
003307:0000 File 00002.m2ts was added as title #3
003025:0000 Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00040.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00019.m2ts was added as title #4
003025:0000 Title #00020.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00023.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00024.m2ts was added as title #5
003307:0000 File 00025.m2ts was added as title #6
003307:0000 File 00026.m2ts was added as title #7
003025:0000 Title #00027.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00035.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00036.m2ts was added as title #8
003025:0000 Title #00037.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 233 at YcO6e1Pv5V5RyV5TOFr0TTIs:0
001003:0020 DEBUG: Code 233 at wO6ce5+ESWTctwQHxzws7l9q:0
001003:0020 DEBUG: Code 233 at K57u7nXfsK38l0fvQeEL5V5B:0
001003:0020 DEBUG: Code 233 at dpUcUn2azrjsXD5r9XaweQsP:0
001003:0020 DEBUG: Code 233 at UHJd/cBBSzgdpPbCx47GoZAz:0
001003:0020 DEBUG: Code 233 at Nwu+mt6oyfNK2mUrOW24dOmj:0
001003:0020 DEBUG: Code 233 at 68RboimlbR14N1DOBFu4gsJh:0
001003:0020 DEBUG: Code 233 at pvr4uYOavr3gubwF01Rp+iVg:0
001003:0020 DEBUG: Code 233 at UKE/XSEBCjvHyjjgn7+5x3Gg:0
001003:0020 DEBUG: Code 233 at SXm7w32uGAm/kdUsmWRVPjTX:0
005014:0000 Saving 1 titles into directory C:/Users/Ry/Desktop
THDSF: [truehd @ 0000000025da9e90] Warning: not compiled with thread support, using thread emulation
THDSF: [truehd @ 0000000025da9e90] End of stream indicated.
004007:0010 AV synchronization issues were found in file 'C:/Users/Ry/Desktop/Wolf_Children_t01.mkv' (title #2)
004008:0010 AV sync issue in stream 2 at 1:57:01.973 with duration of 1042.666ms : audio gap - 1251.2 missing frame(s)
001003:0020 DEBUG: Code 0 at O_h|[Z2T<;A(7V><K1g:213132744
001003:0020 DEBUG: Code 0 at O_h|[Z2T<;A(7V><K1g:213137367
001003:0020 DEBUG: Code 0 at O_h|[Z2T<;A(7V><K1g:213135021
001003:0020 DEBUG: Code 0 at 4(yOYXRk(~=y3s-rF"jD,:213135090
001003:0020 DEBUG: Code 0 at Q.'fmXp (O|q=Ba-::213131893
001003:0020 DEBUG: Code 0 at Q.'fmXp (O|q=Ba-::121263406
001003:0020 DEBUG: Code 0 at Q.'fmXp (O|q=Ba-::29393907
005003:0000 Failed to save title 1 to file C:/Users/Ry/Desktop/Wolf_Children_t01.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Sat May 31 17:50:49 2014
Re: Wolf Children US Release
First thing to try - download and install version 1.8.9, from /download/old/ and retry the rip.
There are some bugs in 1.8.10 that cause problems with certain Bluray disks.
Post by mike admin »
Yes, same bug. Overall I'm amazed how many discs have this "0.7 seconds black trailer" at the end. The next version with the fix should be available shortly.
YxmeN
Post by YxmeN »
1.8.9 worked fine. Thanks!
ndjamena
Post by ndjamena »
I have this nasty feeling this is my fault.
