Error while reading input
elisha
Post by elisha »
I'm trying to make MKVs from DVDs I made so I can add subtitles And I'm getting this error over and over even when using different DVDs, different drives and even different PCs. here's what appears at the bottom of MakeMKV window:
MakeMKV v1.8.10 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Elisha/MakeMKV_log.txt
Title #1 was added (52 cell(s), 1:42:29)
Saving 1 titles into directory C:/Video/SHIVAH
AV synchronization issues were found in file 'C:/Video/SHIVAH/title00.mkv' (title #1)
AV sync issue in stream 1 at 0:00:00.030 with duration of 64ms : 2 early frame(s) dropped at start
DEBUG: Code 449 at >0h<1!A`/\w`V\tejhQ:29399404
DEBUG: Code 0 at 4(yOYXRk(~=y3s-rF"jD,:213135090
DEBUG: Code 0 at Q.'fmXp (O|q=Ba-::213131893
DEBUG: Code 0 at Q.'fmXp (O|q=Ba-::121263406
DEBUG: Code 0 at Q.'fmXp (O|q=Ba-::29393907
Failed to save title 0 to file C:/Video/SHIVAH/title00.mkv
0 titles saved, 1 failed
I've tried to attached the log file, but getting a message: "Sorry, the board attachment quota has been reached."
Anybody has a clue why this is happening?
Re: Error while reading input
Try an older version of MakeMKV, to make sure you're not encountering the bug in 1.8.10. You can download the older versions from:
http://www.makemkv.com/download/old/
Mike will have to comment on what the exact debug messages you're seeing mean. But the fact that this occurs on more than one machine and multiple disks means you have to isolate the common elements.
